FT8 and FT4 and the system crashed
Mauro HB9FBG
Hi, I state that I use very little FT8 and FT4 and I do it with my 6400 with WSJT-X latest version.
As I said, I use it little but used it about a month ago and again yesterday and the system crashed. The 6400 had transmissions on its own and the CAT didn't work anymore. I had to reset the 6400 and delete the SmartSDR v3.0.27 to install it again. Does it happen to you too? Do you use a different soft on WSJT-X?
Any advice is welcome.
73s Mauro HB9FBG
73s Mauro HB9FBG
Mauro,
Did Windows perform any update? Which version of Windows? 7, 8, or 10?
Latest Windows 10 (U.S. version) and WSJT-X 2.10 has been stable with SmartSDR 2.5.1 and 3.0.27 except when Windows does a system update.
The same problem has not already been tried about a month ago when I tried FT8. Not so if I'm wrong about something, I seem to have followed the instructions which are quite simple.
Sorry, Windows10
Check this post for setup instructions for FT8. Only thing I would do different than Ria's instructions is set WSJT-X to use Data/PKT mode.
https://community.flexradio.com/flexradio/topics/ft8-setup-with-flex-6300
Another thing to check is see if you have ghosted comm ports in Windows.
https://helpdesk.flexradio.com/hc/en-us/articles/200883925-Removing-Hidden-or-Ghosted-Com-ports?_ga=2.255413952.95221455.1568472289-816311141.1549960535
Привет, откажитесь от Windows10 и все проблемы
исчезнут rw6ab
Thanks Dave,
I tried this configuration and it seems to work. We must see if it does not deteriorate the system because even the first one (https://www.youtube.com/watch?v=vxageEY7-Pw) worked but then it blocked my system.
For now there is nothing that interests me but as soon as there is something tantalizing I will test it longer.
Thanks for the advice.
73s Mauro HB9FBG0 -
Mauro;
I also do not have much in operating FT8 regularly, but I did get it working out of curiosity. I have two instances of WSJT-X running simultaneously, one for each slice on my 6400, each slice on different bands. Using Win7, I have run this configuration for several hours without issues.
- 316 Community Topics
- 574 The Flea Market
- 7.7K Software
- 6.1K SmartSDR for Windows
- 365 SmartSDR for Mac
- 251 SmartSDR for iOS
- 244 SmartSDR CAT
- 177 DAX
- 356 SmartSDR API
- 9K Radios and Accessories
- 122 FLEX-8000 Signature Series
- 855 Maestro
- 50 FlexControl
- 847 Genius Products
- 298 Tuner Genius XL
- 103 Antenna Genius
- 268 Shack Infrastructure
- 189 Networking
- 132 Contesting
- 696 Peripherals & Station Integration
- 131 Amateur Radio Interests
- 921 Third-Party Software
