Internet requirements for remote ?
Andreas Angold
Andreas Angold Member
edited September 2019 in FLEX-6000 Signature Series
I want to buy a 6400 and a Maestro console. The whole thing should work via remote.
My question is, how high must the minimum requirements for the data line DSL Internet
for down and upload be to have a liquid operation?
Many thanks and 73 de Andreas
    Hi Andreas
    At minimum, you should have 1.5/sec up and 2mb/sec down.
    Your upspeed bandwidth is much more important as you are now sending a lot of data away from your home qth.
    Please try not to use any WiFi unless you need to since WiFi is severely impacted both other users, both on your network and even your neighbours who are not on your network.  It is like an old phone party line.
    I hope that helps, Mike va3mw
  • Andreas Angold
    Hello Mike, thank you for the info.
    This is a good info for orientation.
    I wish you a nice weekend ! 73 Andreas TNX!
  • N2WQ
    N2WQ Member
    What are the jitter requirements?
    Hi Rudy
    We don't publish and Jitter requirements, however, in order to be useful, it would be the same as for any VoIP phone call.  Less than 150ms would be preferred.
  • N2WQ
    N2WQ Member
    Thanks, Mike. Makes sense.
