Trade up options?
dlwarnberg
I'm considering once again trading in (if/when) flex has one again my FLEX-6500.... so I am now questioning which Radio would be best to trade up to... the FLEX-6700 or the New model 6600 or 6600M...
So I ask myself... do I need more then 4 slices? No but would be nice to have
Why upgrade? I want to do full duplex SAT without having to use the switches (I use switches between RX and TX side for two separate transverters)..
So I'm debating... wait and trade up at some point and if I do to which radio... stick with what I have and just purchase the IC-9700, it will do everything I need for SAT work as well as local repeaters, etc...
Thoughts?
All feedback is welcome
David
KK4QOE
Thoughts?
David
KK4QOE
Im pretty happy with my 6600... Certainly nothing in the way I use the radio requires me to have the 6700... IMO, I like the current form factor of the 6400/6600 etc. Since the DSP's are the same between 6600/6700, I can only guess that once a new DSP pops, we will see a 6800. Time will tell.1
The 6700 is nice if you do 2 meter SSB.
6600 or 6700 would be my vote but NOT M model 6600. If you want the Maestro then buy it separate so you can use it wherever you want.
Mark1 -
I tend to agree with Mark WS7M. The base 6600 with a Maestro gives you more mobility and flexibility....but everyone has an opinion! Hi Hi!
If you are going to go the IC9700 route, remember it only has one amp port. So if you use separate amps for the higher frequencies, you will have to do some amp switching....
Lou N2TU1 -
Hi David
Off the top of my head:- 6600 and 6700 both give you 2 SCU's. That is a big difference and it allows you to make use of 2 different antennas at the same time
- You get a new 2 year warranty
- The 6600 gives you 7th order band pass filters and 4 slices
- The 6700 gives you 8 slices
- The 6700 gives you 2M at 5mw out but with the addition of the Q5 Signals amp you get 75 Watts out! http://q5signal.com/index.php?route=product/product&path=60&product_id=73. Doing 2M on a 6700 allows you to be on 2M SSB, 2M Meteor Scatter, 2M FT8 and more. All on 1 amplifier, 1 feedline and 1 antenna. You can't do that with any other radio.
- Like I mentioned on 2M above, you can do the same on any other band as well.
- The 6600 can support 2 transverters and be able use both of the at the same time (Again, the Q5 Signals ones are great)
I hope that helps some, Mike1 -
Much depends on what's more important to you, internal 7th order contest filters, or having 8 receiver slices.
If you operate, or plan to operate in close RF field environment such as FD, or have other hams that live close by, the contest filtering of the 6600/M may be helpful, otherwise the 7th order contest filtering is unnecessary.
As for Sat work, the 6700 only has one Transverter port (vs two on the 6600/M), although the 6700 has 2M capability which can drive a second Transverter, so I feel the 1 vs 2 Transverter comparison is a wash.
I've bought my 6700 back in October 2015, and feel there's zero benefit moving to a 6600/M. I enjoy having the ability to open an 8 slice profile and be able to see the majority of HF bands at once. I have no need for contest filters, but if the need ever did arise I could always add them externally. Plus I very much enjoy the low profile of the 6300,6500,6700 case.
My .02.
I vote for the 6700. It has a smaller form factor and includes the 2m band.
Dave
K1DLM
I'm not 100% certain about this but I believe the 6700 also offers one additional level of RF Gain (over the 6600/M)... +40db.
Both good choices.
I went with 6600 non-M and a new V2 Maestro. The Maestro gives me more FLEXability to move about. I also have a V1 Maestro in my office at work and a 6500 installed at a remote location which is shared with our county RACES team.
iPad and iPhone app also works great for impromptu operating.
Thank you.... " I went from a 6300 to a 6500 and it was one of the best moves I made. Having both SCU's makes it worth while." ?? Do you mean from a 6300 to a 6700?? I went from a 6300 to the 6500 so I could do MARS
Good your doing research, I have a few freinds that are very disapointed with the Icom 9700. It drifts off freq after warming up making sat work almost impossible.1
I kind of like the low profile as well....
Thanks0 -
Ouch... that's not good.. have not heard that one...
Thanks0 -
I assume my GPSDO unit would move over to the 6700 without issue?0
The GPSDO from the 6500 will work in the 6700.1
The IC-9700 does drift, but it does not exceed the specs presented by Icom. I did some research on this and you can find some online tests.0
I've read comments here that the 6600/6600M has better cooling due to the larger case and possibly more reliable fan than the 6700.
I don't know if the cooling is really better. But different, with advantages.
They moved to one fan, down from four fans.
The larger fan runs slower.
They added 50% more cooling surface to the new radios.2 -
Thanks for the clarification Bill.
BTW, one nice feature of the M models is the HDMI video out. You get the advantages of a big screen without a PC and those pesky MS updates. And even if you mostly use SSDR, having a built-in client in the radio can be handy at times.
good point0
In addition, Being able to monitor up to 8 repeaters at the same time during an event has great valve. You can graphically see which ones are active and un-mute faded left,right or centered.1
Personally owning a Flex-6600M and several Flex-6700s (and a Flex-6300 as a backup) you have some really good choices with the 6600 and 6700 series.
I think the posts above all explain the differences pretty well.
If I was told I could only keep one, I think I'd keep a 6700. I like the build quality feel of the low profile unit and while perhaps a party-piece the eight slice capability is without peer.
But I wouldn't be truly unhappy with either one, especially if my option was a non-FRS radio!
Steve
K9ZW
Blog: http://k9zw.wordpress.com
Being a owner of both a 6700 and 6600M and if I was forced to sell one of my radios I would definitely rather sell the 6600M.
I have had the 6700 for several years and is one of the special addition Signature radio's and Yes I got the jacket.
The extra filtering on the 6600 is nice if you have a close by station transmitting or maybe a multi user field day BUT with the "RX loop" through on the 6700 which unfortunately the 6600 doesn't have the 6600 has missed the bus for me.
Here is why
With the RX loop through on the 6700 you can easily add a inexpensive band pass filter, RX overload device, Broadcast band filter or other inexpensive filtering device that can be easily home brewed or cheep to buy because they are really low power and just plug in to the BNC jacks on the back of the 6700 I find this FAR superior then what the 6600 has.
I used to have a next door neighbor that even shared one of my Towers that would run full legal power and I have found that I had no problems with RX overload having a overload device in the RX loop I never had a alarm or other issues, I built a Broadcast band filter and had the overload device and the BCB filter in series, I had no problems other then having to run a step up in the Pre-Amp to bring the RX up to where it was supposed to be.
This is my OWN opinion and not trying to sway anyone one way or the other.
Bret
WX7Y
Bill this is not true. Latest firmware allows the IC-9700 to be GPSDO locked: freq stability is now excellent on all bands. I have an IC-9700 and would highly recommend it to VHF and UHF enthusiasts. Paul M0CVX1
In the UK there are no trade up deals. I’m just off the Phone with Martin Lynch who wants $6110 for a new 6600m against $1120 for my limited edition 6500 on version 2 software. Just ridiculous, looks like that’s the last Flexradio I’ll be buying. There really is no traction for Flex in the UK due to dealer greed.0
Your other UK dealer (Nevada Radio) has a display 6600M on offer at UKP 3700 (roughly $4600), so work your options. (Not certain if your 20% Tax is included or excluded, but does sound better than the $6100 price either way).
The trade-up deals from FRS itself are its domestic market offering, with few overseas distributors able to match that program with one of their own. It is market sensitive for allowances offered. Some people have found it a good deal while other have complained.
The low allowance your one dealer offered appears below market, which is their signalling that they really don't want to handle your radio as a trade-in. Predictably you will find your direct resale price achieved should be more.
For those in the USA domestic market we tend to get riled up seeing the add-on costs in other markets. What we tend to not include is that these dealer/distributors are not part of the factory, they have all sorts of additional costs ranging from import costs, local support arrangements (including training), to various sorts of regulatory costs - all unique to their market. In the UK a 20% VAT (effectively ends up like our sales tax in terms of costs) gets applied as well in most cases.
This is nothing new, unique or special to this radio - one of my vendors did a one-off sale to a mutual client for one of that end client's UK sites and the add-on costs easily exceeded the cost of the actual product. This vendor did it as they have a corporate level program and the costs will be diluted across the overall sales to the end client, but the numbers were stunning.
Sometimes an individual can make a small scale personal import to avoid much of the extra costs, but at the expense of uncertain support, unenforceable warranty, and having to scramble for spares. Here we call this sort of product either personal imports or "grey market" product.
Steve
K9ZW
Blog: http://k9zw.wordpress.com0 -
Steve, the model from Nevada Radio is the 6600 not the 6600m, you can add another $1200 for an m model believe it or not. That particular radio has been on sale for months without interest and Nevada have no new stock. This leaves Martin Lynch in the UK to rule Flex prices if you want one today.0
I also went from a 6300 to a 6500 -- a VERY good move IMHO.
Sorry I missed that one wasn't a M-model.
How much of the pricing issue might be from the low UKP value in USD?
The spread between this 6600 and a 6600M if it includes the 20% VAT it is the spread to be expected.
The $6110 you were quoted for a new 6600M if VAT inclusive is also really right on the mark.
Thinking the wrangle is that they made you an offer for your trade-in allowance that you feel is too low you might see what you could get for the old radio open market selling it yourself?
Not telling you what to do in turbulent times, but you may want to check UKP futures to see what your potential transaction might look like if Oct 31st brings the promised change. As I type nearly 2/3rd of FX analysts are saying to buy UKP as they expect the value of the UKP pound to rise, but the studies do note high volatility. That does mean that more than a 1/3 say it ain't so, and sell your pounds.
GL and 73
Steve
K9ZW
I can bet you that the 9700 can't do this. And I still have a spare slice.
3
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 179 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
