SO2R timing issue
Les Brown
I have my 6600M set up for SO2R/2BSIQ operation. I have a timing problem when switching bands. Details of the setup: N1MM logging with 2 keyboards, SmartSDR v2.4.9 on the PC, PTT with TX1 for slice A and TX2 for slice B fed to 4O3A 1A2R switch and from there to Expert 2K-FA amplifier, serial port from the PC to Port 1 of the amplifier, N4PY software controlled by Behringer CMD Studio 2A, 4O3A 2x8 Antenna Genius, VA6AM diplexer, triplexer and high power bandpass filters. The amplifier is always using Port 1 and is shared between the 2 capture units of the 6600M by way of the 1A2R switch. Problem: When I switch bands by hitting a function key in N1MM to transmit on the slice that is not currently in focus, PTT triggers immediately but the amplifier doesn't receive the band change information. I put a 2 second TX delay in the 6600M to see what happens and the amplifier only switches bands after the 2 seconds has expired (using RF detection instead of received frequency info across the serial interface). I had N4PY analyze the situation with his software and he found the following issue:
"The problem is the message from N1MM is not coming to me until the TXDelay ends and I don't understand that. Also the change in transmit slice message form the radio does not come to me until the TXDelay is over. So both the message from N1MM and the message from the radio don't come to me until TX Delay is over."
So, is there a problem with my configuration or is there a bug in either the Flex software or N1MM???
Please help. Dueling CQs is likely harming my relays with hot switching.
73, Les VE3NNT
73, Les VE3NNT
Hi Les
It might be better to open a support case on this one.
Hello Mike,
This is off the subject. Need a little help getting my stream deck setup. got the
stream deck software. Went to frstack3 proterties . clicked on the rest file and plug in. Opene stream deck and chose frstack3. Can't find frstack info on right side of stream deck soft ware. Lost...….
Can you give me a little help?
Don...w2xb
I submitted a support case to Flex last week involving hangup in 2.51a involving CW paddle conflict with n1mm macro and the time delay. They transferred it to software as a possible bug since I can duplicate it 100% of the time on a 6300 and a 6400. No problem before 2.510
Les,
I am using the same 1A2R switch with my 6600M and N1MM. You need to allow for more time to switch.
See https://groups.io/g/N1MMLoggerPlus/message/42078 for details.
Andy
KU7T0
- 383 Community Topics
- 640 The Flea Market
- 147 SmartSDR+
- 435 SmartSDR for Mac
- 262 SmartSDR CAT
- 201 DAX
- 280 FLEX-8000 Signature Series
- 958 Maestro
- 935 Genius Products
- 343 Tuner Genius XL
- 305 Shack Infrastructure
- 214 Networking
- 142 Amateur Radio Interests
