RJ-USB6000 Desperately Needed WTB
Dawg Fan
Dawg Fan Member
edited December 2019 in FLEX-6000 Signature Series
I desperately need the Ameritron part number RJ-USB6000 to interface my 6500 to the ARI 500 connected to my ALS 1300 amp. These cables are not in stock at MFJ nor HRO. If you have one surplus to your needs please contact me at N5TF at Yahoo don't com.
  • Brian Denley  KB1VBF
    Brian Denley KB1VBF Member ✭✭
    edited November 2019
    I ordered one a week ago but, as you said, they are back ordered.
  • Dawg Fan
    Dawg Fan Member
    I called MFJ and they don't know when more may be produced.
  • stu
    stu Member ✭✭
    easy to make .. i use it with my 6400 and als-1300 .. you need this cable ..
    https://www.mouser.com/ProductDetail/ftdi/c232hm-edhsl-0/?qs=EB8w3yL7SqPZGmdI8JhrMA%3D%3D&countrycode=US&currencycode=USD
    Here is the cable mapping:
    FTDI Pin 2 Orange to ARI Pin 7 Brown/White
    FTDI Pin 3 Yellow to ARI Pin 6 Green
    FTDI Pin 4 Green to ARI Pin 5 Blue/White
    FTDI Pin 5 Brown to ARI Pin 4 Blue
    FTDI Pin 10 Black to ARI Pin 1 Orange/White
    take any cat 5/6 network cable .. cut off one end .. connect as shown above ..
  • Dawg Fan
    Dawg Fan Member
    edited August 2019
    edited August 2019
    Looks like an opportunity for Flexradio!
  • Dawg Fan
    Dawg Fan Member
    edited August 2019
    Stu/Anyone - do you recall the settings for the USB Cable in Smart SDR?
  • Dawg Fan
    Dawg Fan Member
    I made mine BCD and it seems to work fine.
  • stu
    stu Member ✭✭
    edited August 2019
    bcd is right .. glad you got it going ..
  • Dawg Fan
    Dawg Fan Member
    edited August 2019
    Thanks for your help.
    edited August 2019
    Ameritron has just notified me that they have shipped the RJ-USB6000 cable to me.
    edited September 2019
    I can report that the RJ-USB6000 cable works as advertised. That cable and the ARI-500 gives you full auto band switching. You will also need an RCA cable from the TX1 jack on the Flex to the Relay jack on the amp, as well as an RCA cable between the Flex ALC jack and the ALC Jack on the amp. I did find out that the Default TX profile does not activate TX1 so select SO2R or make up your own profile.
  • W7NIK
    W7NIK Member ✭✭
    How do I test that the FTDI is working correctly ?  I cannot get the amp to switch, not sure if it is  the FTDI or the RJ45 board on the amp ?  ARI 500 is new  .
    Please help  w7nik..
  • stu
    stu Member ✭✭
    the ari has two lights .. both should be on solid .. you can also go to usb cables in smartsdr and run the log and see what is being output ..
  • W7NIK
    W7NIK Member ✭✭
    lights are solid,  the cables from the amp , should go to the amp ports on the ARI 500? conflicting information:(  to the remote using the c232HM EDHSl-o
     my settting are BCD tX ant, it worked the first day  couple weeks age , :(
  • stu
    stu Member ✭✭
    the cable from the flex plugs into the front ..
    the amp cables plug into the back .. i have a als-1300 ..
    i dont know what the c232HM EDHSl-o is ..
  • W7NIK
    W7NIK Member ✭✭
    yes that is  what i have, the BCD data is not telling  the 1300  the right data .I have the FTDI cable , i  would like  to find out if the RJ45 board on the amp in not working or the FTDI cable . challenging :)
  • stu
    stu Member ✭✭
    did you buy the ready made cable ?? i made my own .. are you sure a and b cables are not reversed ?? other than that i would have no idea .. sorry .. good luck ..
  • W7NIK
    W7NIK Member ✭✭
    I will test your  FTDI maping colors, maybe something came loose
  • W7NIK
    W7NIK Member ✭✭
    Your mouser link is my FTDI cable :)
