Display Average changing
edited January 2020 in SmartSDR for Windows
I can't seem to keep my Display Average setting to stay the same. Sometimes when I restart the software it goes to my global setting of 75. Other times it reverts back to the default 50. No pattern that I can tell. Any clues on how I can make it stay put?  Running 6400 and 2.5.1  TIA!
73 Dan KG0AQ
Welcome!
  • Member ✭✭✭
    edited July 2019
    Ive noticed the same thing, I have mine usually set to 80, but it often resets to 50.  Ive given up changing it back to 80 for the present time
  • Member ✭✭✭
    edited January 2020
    Same here, have to reset it to 80 every time I start SmartSDR.
  • Member ✭✭
    edited July 2019
    What is "Display Average"? Ian VA3QT
  • Member ✭✭
    edited July 2019
    It is in the left horizontal menu on the panadapter under Display then Average. It speeds up or slows down the panadapter reaction speed. Default is 50 and way too slow for my taste.
  • Member ✭✭
    edited December 2019
    Loading a profile when you start SSDR will ensure all the settings are restored to the saved value.
  • Member ✭✭
    edited July 2019
    Much tnx Ian VA3QT
  • Member ✭✭
    edited July 2019
    Thanks for the tip but I don't really want to mess with that step every time I load the software. The software "should" remember the last global profile when you shut it down. 3 out of 3 say they have the issue so Flex folks is this a known bug in 2.5.1? TIA! 73
  • Member ✭✭✭
    edited July 2019
    Im using v3.0.27 with this problem
  • Member ✭✭✭✭
    edited July 2019
    Could it be that the Global Profile in use sets the Average to an undesired amount?
    My 6400 using 3.0 doesn't do this.
  • Member ✭✭
    This problem has hit again. Every time I start SmartSDR 2.7.6 my average display value reverts to 50. I have loaded and saved global profiles with no joy. Why does this discussion say "answered". What is the "answer" or solution to this issue?
    73 Dan
  • Member, Super Elmer Moderator
    Hi Dan, the forum software marks a question as Answered as soon as a response is posted. Not the most useful, but there you have it.
    I don't have this issue with 3.2.39, but when I get a chance next week, I will down grade to 2.7.6 to see if I can recreate the issue.
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    Dan,
    If this is failing on 2.7.6 for you, please open a support ticket. They will make sure it gets correctly logged as a bug if that is the case.
  • Member ✭✭
    Mike,
    Will do! Thank you.
    73, Dan
