problems with dax followin g update to 2.5.1 and windows 1903
Roger G3LDI
Flex 6600 I5 quad core new PC N1MM+
Upgarded to 2.5.1 and Windows 1903. Messed up the DAX drivers. I have followed Tim Ellisons instructions, several times, including uninstalling the DAX drivers in the 64kbit directory running as administrator. I have managed to get receive RTTY and PSK to work, but for some reason when looking at soundcard settings in N1MM, there is NO DAX TX showing, just lots of RX. TX seems to have disappeared. Help greatly appreciated. Streaming is on in the DAX window, but no red bar showing.I have checked all the DAX channels on slice A, but only channel 1 will work on receive anyway. I have done all the above lots of times, rebooting each time. I do have Teamviewer if that helps. 73 de Roger, G3LDI
2
I had the DAX problem a couple of months back and Tim gave a great response from a Help Ticket
Good luck
73 John0 -
Hi Roger,
I have dax issues every time I do an update to windows. I had Tim help the first couple of times but now I am able to resolve things with a little effort. My issues have always revolved around renaming the dax drivers to be correct. I had a slightly different issue this time. This time drivers were missing not just named incorrectly. I found that if the renaming during the update created drivers that had the same name then the the driver with the duplicate name would get hidden and disabled. I finally found two screens that would show which drivers were disabled so that I could rename them and only then enable them.
I will show several pics that hopefully show what I found. The first is the way I have always found it in the past. notice that all drivers were there but just named incorrectly. I mapped the ones on the left that were incorrectly named and showed after renaming to the ones on the right
Next this is what I found this time. Notice that the Dax IQ Rx1 etc were not even shown.
I finally found this screen that showed the drivers that were disabled and hidden.
Notice that these had been renamed respectively by the update process to the same as ones already in place. This is why they were hidden and did not show up. Each of these need to be renamed from DAX Audio RX 2 to DAX IQ RX 2 for example.. After they are renamed then they can be clicked on and enabled.
After renaming then I checked and found they were now correctly in place and renamed.
You can rename from this window
You can have a hint as to what the name is supposed to be by looking at description below the incorrectly named driver name. Rename here.
In most cases I have found that just uninstalling and reinstalling the DAX drivers does not correct the issues unless you are lucky.
Of course Tim can do this very quickly as he has done it many times. It is getting easier for me now that I have done it several times and actually only takes a few minutes.
This last time I used Revo Pro to uninstall everything and made sure that all hidden audio devices ghosted were gone as well but still had the issue.
I have found for me it has always been about renaming the drivers.
Hope this helps.
Ray5 -
Hi Ray. I have been trying all the afternoon to get my DAX sounds in Device Manager to look like this. I cannot seem to be able to achieve it. I am not sure dfhow you"map" them to the correct places either. And I can not see the DAX files as you do. I will keep on trying though!! Many thanks for your help. I am not as computer trained as you or Tim I guess ( I am 81!! ) but I won't fgive up.
Roger
Sorry I missed you last night in the IRC channel, give it another try. I can work with you and get you fixed up.
#FlexRadio IRC Chat73, Jay - NO5J
Roger
Our timezone differences are going to make this a challenge, but I have no plans currently, so I will go sleep, and try to be back at the keyboard, in the IRC channel starting from around the time you joined the channel last night.
Hey Ray - The Microsoft cumulative update 1903 caused the naming irregularities as you so well described. Great find! After changing the "Audio" references to "IQ" everything started to fall back in place however I did notice that a number of my CAT assignments (as noted in the CAT Control Panel) disappeared and had to be re-established. A few hours of time to get everything back in order... Thanks Microsoft!
Hi Roger - its sll pretty confusing for sure. The very first pic i showed was the way previous updates **** with the names. The current one renamed several the ssme therefor hid and disabled them
But just start by looking at the right side. The order and names are correct in in the proper sequence.
Now look at the left side and see how they looked when i first opened them to look. If you go to the first one listed i drew a red line to the correct name. To give you a hint as to how they should be named you can look at the name in the parathesis and the first name is relatedto that.
If you go down the list i think you will start to see what i mean.
Rensming things worked well until this last update when windows renamed several drivers wirh the same name. This caused windows to disable and hide the driver. So just do a search for manage sound devices. Look for the disabled drivers. You must rename before enabling them. If you look at the name in the () and the correct name list i showed then i think you can see what they should be named. The name needs to be corrected first.
Of course you can always open a ticket Tim does a great job but does not slways have time to explain. I have tried to learn cuz it always happens on the weekend. Reach out to Jay as he can also help. Hope this helps
Ray I also looked on line to see how to prevent windows from automatically updating. At least then i can pick the time and place.0 -
Hi Ray.
Again, many thanks for a very comprehensive explanation. It really all comes down to a lack of knowledge on my part. Trying to learn as you go is not always a sensible option. It would be good if there was access to some detailed instructions/education as far as DAX is concerned.A couple of other locals are also keeping an eye on my proceedings! In fact, Malcolm G3PDH now has his working with the DAX names in the correct order.
Jay has offered to come in on Teamviewer to fix mine so I think I will wait for him to do that via Teamviewer and watch what he does. I just hope he is not like a local computer engineer here in Norwich. When he does things it is so fast it is impossible to follow him!
You should put out a series of help files I think because you obviously took a lot of time to explain together with the diagrams. I am trying to save that....
73 de Roger, G3LDI
Thanks Ray for your helped. It works Had Tim do first computer and followed your guidance on two other devices. Rick, K2RB0
Hmm I have the same problem after the windows 1903 update, even though I had completely uninstalled smartSDR and dax drivers before the update, but can'rt figure out the proper renaming, I do see that my Rx2 IQ is named wrong0
Well after some more messing around I think I got it renamed properly now, at least my second DAX channel is working again ....
Well done, Wim. I'm dependent upon Tim and others at FRS. I'm still unsure about Tim's recommended pre-upgrade process - see my earlier post in this thread0
Everyone talks of renaming a driver but never explains how one renames them.
Follow instructions from Ray (K6LJ) in this post...
https://community.flexradio.com/flexradio/topics/problems-with-dax-followin-g-update-to-2-5-1-and-windows-1903?utm_source=notification&utm_medium=email&utm_campaign=new_topic&utm_content=topic_link
and Ray K6LJ mentions how to do it above as well just read his detailed steps0
Ray - New 6700 owner here and one week later Win 10 auto update broke things. Glad to Google and find your well illustrated help. Your screen shot listing the correct name / labels was a really nice check list that got me back working! 73' Lloyd0
Your welcome. It is regular every time I do an update. I looked on líne and disabled the auto update so at least i update with a time of my choosing. Makes a big difference. I just update when i know i have time. I backup my profiles then uninstall SDR and then the update. After reinstalling SDR i dont even start the program until i check the DAX names there is always 3 or 4 needing to be renamed.0
Very helpful... will do... thanks!0
https://drive.google.com/open?id=12GYKlt0UxIVPLYd1ONLpEq1EsCStBytd forse queste foto possono essere utilihttps://drive.google.com/open?id=1Ko_M7X5_Okzr3fr83v_6msruw8lqr5B1
---https://drive.google.com/open?id=1tLlx4qTJaqAa6g59eF7qTqZ1p6UFzMuM
---https://drive.google.com/open?id=19X1mheri-j-rdqGZsxN9KE1YqSc0jCZQ
Roger,
Thank you for the detailed explanation! It saved me many hours!
All the best!
K2SAB
- 354 Community Topics
- 618 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 413 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 377 SmartSDR API
- 9.2K Radios and Accessories
- 25 Aurora
- 218 FLEX-8000 Signature Series
- 923 Maestro
- 897 Genius Products
- 325 Tuner Genius XL
- 116 Antenna Genius
- 287 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 759 Peripherals & Station Integration
- 979 Third-Party Software
