Setup for Heil Pro-Micro with Maestro using MIC2
I am trying to set up my Heil Pro-Micro (T/S mono plug) to interface with my Maestro. Bias is on on the Maestro and I have built an adapter cable to convert to the TRS jack on the Maestro. I can find little info on how the Heil Mic is wired. I have the drawing for the Maestro plug configuration. What should the wiring for my adapter cable be? I am using a foot switch in PTT for the TC PTT. Is there a Flex adapter cable for this Headset?
Also I have an FHM-3 Mic that was sent with the radio but it will not connect to the Maestro What do I need for the FHM-3 mic to use it on the Maestro?
FLEX has an adapter cable, It actually is the same as the Yaesu modular cable. Heil has a cable for the modular jack on the Maestro. There is a less costly adapter from INRAD
Neil N4FN0 -
TNX for the reply. Was the Heil adapter an AD-1-Y-M? It looks like the Kenwood adapter except the RJ45 color is yellow for the Yaesu?0
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
