Setup for Heil Pro-Micro with Maestro using MIC2
Greg
Greg Member ✭✭
edited July 2019 in Maestro
I am trying to set up my Heil Pro-Micro (T/S mono plug) to interface with my Maestro. Bias is on on the Maestro and I have built an adapter cable to convert to the TRS jack on the Maestro. I can find little info on how the Heil Mic is wired. I have the drawing for the Maestro plug configuration. What should the wiring for my adapter cable be? I am using a foot switch in PTT for the TC PTT. Is there a Flex adapter cable for this Headset?
Also I have an FHM-3 Mic that was sent with the radio but it will not connect to the Maestro What do I need for the FHM-3 mic to use it on the Maestro?
  • Neil   N4FN
    Neil N4FN Member
    edited July 2019
    FLEX has an adapter cable, It actually is the same as the Yaesu modular cable. Heil has a cable for the modular  jack on the Maestro. There is a less costly adapter from INRAD
    Neil   N4FN
  • Greg
    Greg Member ✭✭
    edited June 2019
    TNX for the reply. Was the Heil adapter an AD-1-Y-M? It looks like the Kenwood adapter except the RJ45 color is yellow for the Yaesu?
