Seting up WSJT-X with 6400M
What are you exactly struggling with?0
This is all what you need. 73 de OD5TE0
Hani could even remove the PTT port and use CAT for PTT and should eliminate the need to create a PTT port.
If you use SliceMaster, there is almost no setup other than your personal preferences.
You will need to set up CAT and DAX (and enable DAX channels on the radio). Sorry, I don’t do Windows so can’t help directly, but setting up a CAT channel on your PC with an appropriate port is necessary. Whatever port number you set up in CAT TCP you refer to as “127.0.0.1:” in wsjt-x. Set wsjt-x to use “Flex 6xxx” as radio type. CAT for PTT works fine. (Of course when I started this response, all those others weren’t there :-)0
Follow the Youtube details to set up your CAT and DAX
https://youtu.be/vxageEY7-Pw 0 -
Nice job Honi with the screen shots! with WSJT. Under the MODE settings I have mine set to "Data/Pkt", other wise you have to manually change modes instead of having WSJT doing it for you automatically to make sure ur in the the correct mode, but thats just me lol0
Good point. will try it. I run FT8 on USB and do manually have to adjust the mode especially when operating on 40m. Recently I have been using JTX. If you have not tried it yet, give it a shot. Much more sensitive on the RX and better decoding results.
Hani, if ur running "Digital Mode" I think its best to switch the flex to digital mode because it will bypass the filters used in USB or LSB. When Flex is in "digital" it gives you a full 3K bandwidth, 0 to 3KHz. You can use USB but WSJT likes it better if the radio is set to a digital mode and NO eq or processing. Ive been running FT8 for the past month and the bands are nuts, check out 6M, its gone mad!!! 6M has been crazy all day long, from 6am CST to midnight for the past 2 weeks! I must have made over 1K contacts just on 6M using FT8 mode with just a Dipole at 12ft. and 50 watts!0
Thank you for the tips Vidas. Will do that going forward and see how it goes. Indeed, it has been going mad on FT8. Been enjoying 6m, 20, 15, 10 and 17m and collecting interesting awards. I assume you are running the AAC software. I doubt we can connect on 6m ( I have 4 El beam by Diamond), but I hope we connect on 20m. 730
I am using JTDX now for FT80
Hani, Should be no problem for us on 6M if conditions stay as they are.
Had to pull all my coax away from house, having some thunder boomers in area now. Haven't tried JTDX yet, that's next on the to do list lol
What is AAC ?0 -
Ultimate AAC is the software you use to generate similar to the attached.
I have read and listened to this thread many times and still can' t get wsjt working. Running 6400 , ver 2.3.1 wsjt, win 10 When I bring up wsjt NO network server shows up. My computer is on an ethernet connection, the IP adr of computer is 198.......12, Am I supposed to put that value in? I notice a lot of videos show a server value of 127..... What am I mising?? Really fustrated0
You probably would have better luck getting help if you start a new thread - this one is really old.
You do not connect wsjt-x to the radio directly, you connect to instances of CAT and DAX, which are normally started up along with SmartSDR. Fortunately or unfortunately there are a number of ways to connect a CAT interface, either as a Flex interface with local host IP address (the 127.0.0.1 you refer to), a HamLib interface also using that localhost address. In those cases the port numbers (the part after the “:” in “127.0.0.1:4532”) are different, and set up as part of the CAT configuration. It is also possible to allow SSDR CAT to set up COM ports, then you use a serial interface.
Sorry, I’m a Mac user, so not able to give you real specifics - I’d suggest that new thread!
I have mine set up as a Kenwood Ts 2000 and I set a com port in CAT to use with WSJT and it works fine.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
https://www.youtube.com/watch?v=_ww8CcGNAzg
