Web Switch suggestions
W5AP
Please post suggestions for a web switch I may purchase to turn on/off various shack components over the internet for remote operation. Looking for a device with a GUI that can be used to internet control power to radios/antenna controllers/computers/etc either directly or through 12V relays that I can build in a box. Thanks, Jim
I recommend this one from Digital Loggers. https://dlidirect.com/ They have gotten very pricey but are a great piece of equipment.0
Jim
If you search in the community, there is a lengthy discussion on this. I think this is it: https://community.flexradio.com/flexradio/topics/a-cost-effective-web-relay-control
I have found that the Wemo and iHome ones fail when you need them most. They just disappear offline and you have to manually unplug them to reboot them.
I have no focused on these ones since they just work and I don't have depend someone else to broker the connection. https://www.ebay.com/itm/KMTronic-LAN-Ethernet-IP-8-channels-Relay-board-WEB-BOX/281238587151?hash=item417b20470f:g:LlYAAOxyrUVRnG9W. The KMTronic support is really great too and then you can expand it into more if you need to.
I have focusing on making the complete 1 GUI interface using a an PI and NodeRed which IBM developed and is module based.
I hope that gives you some ideas.
I use the "SONOFF" simple WiFi devices
Cheap and they work - I am sure there are other similar makes - I know you can get a "Multi Device" with 4 switches in one.
For me I have PSU and remote "On/OFF" for the 6400
https://sonoff.itead.cc/en/products/sonoff/sonoff-basic
A more advanced system would be needed for a complex station control
As I advance my remote requirements, my setup will evolve.
Phil G4UDU
Thanks to everyone for great suggestions and links
73, Jim0 -
Hi Phil
I tested the Sonoff wifi devices and there was no way I could get it to connect to my Eeros Mesh. I even tried their manual method.
I'm glad you've gotten it to work and it is stable for you.
73, Mike
I also use Sonoff devices flashed with Tasmota firmware. Once flashed with Tasmota firmware the devices are able to be integrated into home automation software and have many more features and functionality than stock firmware.0
I use remote power switches from Amazon and the 5G Store. The remote power switches from Amazon are about $20 for two switches. The load capacity is 16 amps on each switch, which is more current than most switches can handle. You could increase the current capacity with a relay device. The switches can be controlled by my iPhone. They probably also have an Android app. There is a built in scheduler in the app for probably as many on / off events as you want to create.
I use two remote switches for two gutter heating cables to melt ice in the gutters in the winter. The heating cables draw a far amount of power, but less than 16 amps each. I use another remote power switch to turn on and off my fountains in the summer. I use another remote power cycle my HDHomeRun Prime cable card box for my SageTV computer based DVR system.
These remote power switches are rated highly in the product reviews. I plan to buy more remote power switches because they come in very handy to remotely switch and schedule electrical devices. They would also be very useful to remotely control devices for a remotely controlled HF station.
Another very useful remote power switch to consider is a an Internet sensing remote power switch. These remote switches are more expensive. This type of switch is available from the "5G Store". It senses when you lose Internet connectivity. The remote power switch then can automatically power cycle your cable modem, router, and Internet switch. This type of power switch are rated highly by snowbirds who periodically had to call someone to drive to this home and manually reset the power on the cable modem, router, and Internet switch. I've looked in the log, and did see several times where the Internet sensing remote power switch power cycled to restore my Internet connectivity. After I installed the Internet sensing power switch, I never notice Internet outages anymore, that require manual power cycling of those devices. It's well worth it to eliminate that annoyance from your life, and very useful to have if you're a snowbird, and don't have to bother someone to physically drive to your remote home to cycle the power on those devices.
Remote power switches on Amazon:
https://www.amazon.com/Gosund-Compatible-Control-Required-Anywhere/dp/B07NSXFWK6/ref=sr_1_10?keywords=Smart+Plug%2C+WiFi+Remote+Control+Outlet&qid=1560347540&s=hi&sr=1-10
Remote power switch from 5G Store:
https://5gstore.com/product/6081_2_outlet_ip_switch.html
Mike, Love your NR interface. I am also using an RPi and NR to control my station including a 4 port antenna switch. I use an Amazon Echo to actually talk to NR if I don't want to use a Dashboard.0
Ken
I would love to share some Flows and really get more Hams working with NodeRed . I will share my KMTronic Flow and the KPA500 flow (it isn't down yet).
I have a thread on NodeRed running in the SmartLink area. Feel free to share if you wish.
I would like to integrate SIRI or Google, but I have yet to get that far.
Have two and they are great not one issue and gives me 18 switchable ports, 8 on UPS power items and 8 on a standard power source.
Full remote control; site. Have one port for PTT as well for upgrades etc.
Hey Mike. Good idea. I'll check out your thread. If you are interested in using voice commands with NR I highly recommend getting an Amazon Echo Dot ($35). There are several NR contributed nodes available including 1 that requires no skills development. It just works and is extremely easy. I can help if you need more info and we shouldn't hijack this thread. Hi hi.
Ken0
- 335 Community Topics
- 602 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 400 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 178 FLEX-8000 Signature Series
- 913 Maestro
- 882 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 280 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 736 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 950 Third-Party Software
