WSJT-X Tx signal not getting to Dax
After happily operating FT-8 through my remote base, I am beginning to experience intermittent failures with WSJT-X 2.0. Audio is not getting to Dax Tx. Checklist:
√ Dax 1 set on slice flag
√ Dax set (blue) on P/CW tab
√ Dax control panel TX blue (and Rx1)
√ PC Sound Volume settings max
√ WSJT-X CAT and PTT working
√ WSJT-X Audio Out: Dax Audio Tx
Tones are produced by WSJT-x when audio out set to spkr
When FT8 goes into TX mode, Flex MOX lights up but there is no power output and no streaming activity indicated on Dax TX. Dax Tx does switch from streaming to transmitting, but no output. Tx Gain set to near max. Results are the same whether operating Maestro or SSDR. Rebooting wsjt-x and PC didn’t work.Ideas? TU.
What is your High Cut set to? If in FT8 you're transmitting on say 2400 and the high cut is 2000 then you will have no output.
Check "Setting The Transmit Filter Bandwidth" in the SSDR manual
what mode is set at TRX?
A few things to check
- Make sure in WSJTx, you have DAX Audio TX (FlexRadio Systems DAX TX) selected for TX
- Make sure in SmartSDR you have DAX selected as an Audio input
Thanks for the feedback. I hadn't thought about the High Cut setting, but it was set for 2900 so I guess that's not it. The mode is DIGU. The Dax Audio Tx is the wsjt-x output setting...and I do have the Dax button selected as the primary source for audio input. It seems to not make it from wsjt-x to Dax.1
You may have a corrupted Windows TX DAX port.
Make sure the DAX TX one is named exactly as I typed it in.
If you haven't reboot the radio from a DC power off and maybe do an export profiles, do a full reset on the radio and then import them (your settings).
If that fails, open a support case to have them check on the Windows sound settings.
Thanks, Mike. I think this must be a windows problem. The situation that I have described is for the PC in my shack (not the remote base). If I operate the PC at the remote base via TeamViewer, it keys the radio appropriately. The setups appear to be identical. This would seem to indicate that the radio is not the problem. To make things even fuzzier, the remote base wsjt-x transmits, but is not copying signals. Both configurations were working as expected a few days ago. My remote base connection is marginal bandwidth and the radio disconnects frequently. However, my friends and I have 3 Flex's on a Smartlink network and the other radios exhibit the same behavior and there is good bandwidth to the other 2 radios.0
All, I will agree that this is a Windows issue. I have the identical problem and, like everyone else, wsjt-x TX audio worked one day and failed to work the next. I have removed and reinstalled the Flex ecosystem (which has cured this issue in the past). Has anyone resolved this issue (short of reloading Windows 10)? Like Chip, I can redirect the wsjt TX audio to the headphones and I can hear it (reloaded wsjt, but didn't seem to need to). CAT is working fine, rig keys ... just no modulating audio (no TX stream shown on the DAX indicator). One thing I notice: DAX does not close when I close SSDR. That may provide a hint. Thanks!1
@Sam,
I have been experiencing the same, no WSJT audio to DAX, condition, off and on, for the past 3-4 weeks. I only have to reboot W10 to resolve. Looks like something went wrong with one of the W10 updates, I imagine it'll be fixed one of these days in an other update, hi, hi....
Hi Chip, If your W10 computer was recently updated then your DAX names can get corrupted. they would have to be renamed. I looked on the web and found a way to prevent the automatic update. Look at an example of how my DAX drivers names were changed. on the right is the way they are supposed to be. To rename search the forum it will explain how to rename.
I just started having this same issue with WSJT-x. Renaming the driver doesn't seem to be the issue, as the name "DAX Audio TX (FlexRadio Systems DAX TX)" appears correct. However, when I check the Properties for this device and click the Events tab, I see a message that reads, "Device SWD\MMDEVAPI\{0.0.0.00000000}.{c9b025b6-8e94-4870-996b-2b3f0eca4e3c} was not migrated due to partial or ambiguous match."
So what does it mean to have not been "migrated" and how do I fix that? I tried uninstalling v3.1.12 of SmartSDR (including the DAX drivers) and then reinstalling everything. That didn't help at all.
- 379 Community Topics
- 636 The Flea Market
- 140 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 44 Aurora
- 271 FLEX-8000 Signature Series
- 956 Maestro
- 57 FlexControl
- 301 Shack Infrastructure
- 793 Peripherals & Station Integration
