SteppIR SDA2000 to Flex-6400 USB issue
N8FNR
N8FNR Member ✭✭
I have two different brand FTDI cables and a the SteppIR S12 cable. For some reason I cannot get the either FTDI cables to communicate between the SteppIR and the 6400. The USB log does show activity though. I am using a SteppIR S12 cable too.
The USB cables are shown in the photo. The SDA2000 is set to data in/out 9600 Kenwood. Autotrak is turned on on the Steppir. The S12 is plugged into the data in (top port) on the 2000.
BTW the S12 cable worked with my desktop hooked into a serial port.
Any thoughts on what I am doing wrong? It seems to be set up correctly per the Flex USB Cables Interface for the FLEX-6000 PDF document.
