Version 3.x a no go
Hi,
I bought and installed version 3.x. Now the radio doesn't work at all. It tells me a license is required and even when I click on the refresh button nothing happens other than it says "refreshing radio license state." Help!Comments
You might want to try rebooting your Flex and PC and starting the process over. What happened here was, I initiated the update to v3.0.19, it started downloading. Towards the end of the download a window popped up indicating a new license was required and it asked for payment. This is where I made the purchase. After purchase I was able to open the update.
Does your radio have Internet access? Make sure that your radio is connected to the Internet and then reboot the radio.0
Verify the radio does not have a self-assigned local address (169.x) indicating it has no Internet access. You need the radio connected to a router, or if connected directly to the PC, you must have “Internet sharing” on in the PC.0
Power radio down then back up and see if it works. I had to do that earlier today on my 6700.0
Mine does same thing. I purchased ver 2 in Feb, but Ver 3 says buy. I have done all suggested here but still no go.0 -
Tim, I have verified your order from our records. I have fixed the issue and your radio should now be licensed for v3. Pressing the blue refresh button should get you going.1
Hi,
I guess the radio needs direct access to the Internet. There are two problems with that. This is a new house and the fiber optics comes right up to the house and into the garage. From their modem, there is wiring to take it to a central closet and Wi-Fi takes over from there. I have no direct access to the Internet without going out to the wall-mounted modem in the garage. That's where the second problem comes in. Because I am disabled, I can't get to that part of the garage. I will have to wait until I can get someone to help. I remember now I had the same problem when Flex upgraded to version 2.x. I suspect more more people will have the same problem as new houses are built with Internet access considerations built in. Oh, I have to have special permission to plug in directly to the modem in the garage from the Internet provider.
VC
KCØEM
Hi,
Since version 3 won't work for me, if I go back to version 2.x, will I have the same licensing problem? I'd sure like to have a radio that works.
From your WIFI in the closet, can you do a CAT 5 hook-up to the router? That
would provide your connection. Another possibility could be setting it up at a
friend's house to get it activated.
Hi,
I had the same problem when version 2.x came out. The Wi-Fi box has only two connections – the power and the cable in from the modem in the garage. There are now other direct sampling radios on the market and it's looking more and more like that will have to be my solution.
What about a 5 port Ethernet switch in the closet? Then you can run an Ethernet cable from the radio to the switch. The radio does not need to be physically located near the computer. You might think about relocating the radio to have an Ethernet connection direct to your network of you are ever planning on remote operation. Dave wo2x0
Dave,
The Wi-Fi box is nothing like we might buy at a big box store. It's matte black with the two connections, power and the line in from the modem. Even the antenna seems permanent. Oh, there is a little tiny red LED power light. It doesn't belong to me. It's part of the Internet package.
Dave, maybe call your internet provider and tell them what your having trouble with. I had a problem here after buying a new printer, it would not connect wirless. I call my provider and they went into my router and made some changes and now it all works well. Never had any problems with my radio connections.0
thanks … resolved
Can you not use a WiFi bridge / range extender to create a wired network from your WiFi? There appear to be many available.0
Hi,
There has sort of been a solution. The cable company will come out and we can run a 50 or 75 foot CAT 6 cable temporarily out the front door and around the house through the front of the garage and finish the update. We can't do it tomorrow because the snowstorm predicted, so I will have the privilege of owning a brick instead of the radio for a while longer. A word of caution here – don't buy a brand-new modern home designed to handle fiber optics communications! I wish I understood why an Internet connection was required when we can download the software??
I'm not understanding, how would you download the update without an internet connection?0
I am having the same problem. Asks me to buy even if I bought my Flex in 2019.0
Paoulo, Open a Help desk ticket Include the serial number of your radio. Dave wo2x0
Yes, if you are having issues, please open a helpdesk ticket. You will need your radio ID and serial number.
https://www.youtube.com/watch?v=zO90kVkIYM8
Paulo, if you purchased your radio in 2019 and it hasn't been licensed for v3, we'll fix it for you. Please open a helpdesk ticket with the order invoice to expedite the process.0
I have the same question, but perhaps the computer has Wi-Fi and the radio is connected only to the computer???0
Hi VC. You did not say what kind of Flex radio you have. If it is not an “M”” radio, you obviously have it connected to your computer, and I presume that computer is connected to the Internet via WiFi. If so, all you need to do is “share” that WiFi connection on your PC - your Ethernet-connected radio then has access to the Internet through your PC. It is not trivial, but absolutely works - I do it often using a Linux PC, and Windows has the same capability. If you have an “M” radio, and do not have it connected to your PC, it’s not much more work as long as your PC has an Ethernet wired capability. COnnect your radio to the PC via a Cat5/6 jumper, and again configure sharing of the WiFi connection. If you have no Ethernet wired (RJ45) connection on your PC, you have a bit more hardware to buy - a WiFi bridge to Ethernet. Then connect the bridge and wire it to your radio - it will then share your network and its Internet access.
There are many people on here who can help you out. Ted VE3TRQ0 -
If you're directing your comment to me. I did not realize I posted something that
said I had a problem hooking up for version 3. I have been running it since
yesterday. Or was this for someone else?
Jim N9VC
(That was for KC0EM, who signed with his initials “VC” :-)0
That is correct.0
KC0EM if your computer has Wi-Fi and the radio is connected directly to the computer there is a process that can make this much easier. See the following link:
https://helpdesk.flexradio.com/hc/en-us/articles/115003741486-Enabling-Network-Bridging-for-Link-Local-direct-connected-FLEX-6000s
This way you won't have to run any other cables - etc.1 -
I'm having the same problem. Help Desk ticket submitted. But this shouldn't have been a problem, A company that makes software defined radios should have a "bullet proof" process for distributing its software.
Logan KZ6O
It works fine if you have the radio connected to the router directly as well as the PC connected to the router.
Some users cannot configure their installation to have the radio able to talk to the Internet, which is required to do updates.
Ed G and Eric posted links to Help Desk articles to get network bridging working.
The biggest problem is there are so many different configurations of home networking that some will not work.
Ed,
Thanks for your help. I tried to follow the help desk item without any success. I could not establish a bridge because things were different than what was pictured on the help item. When I finally found something that looks similar and I tried to establish a bridge, I got the error message I am attaching. The cable company is supposed to be here later today if they can make it through the snow. That worked with the last upgrade, so I'm sure it all worked out too. I'm afraid this will be my last attempt at an upgrade. I think I will sell my 6500 because as a disabled vet I can afford upgrades.
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 212 FLEX-8000 Signature Series
- 922 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
