FRStack Version 3.0.19.1 Released
Member ✭✭✭
- Includes FRStack 2 features
- FRStack now support FlexAPI 3.0.19
- multiView support
- TX Band Settings view / edit
SmartSDR V3 supports multiple clients, you can bind FRStack to specific client in order to target client you wish to Tune, MOX or set TX Band Settings.
Sync Client Slices feature will keep clients' slices in sync with each other. The purpose is to allow the use of Maestro as a control surface for SmartSDR when co-located. You must not bind to a client for this feature to work.
Full release history can be found at http://www.mkcmsoftware.com/Flex/Index
Welcome!
  • Member ✭✭
    edited April 2019
    Mark, thank you for the quick update.  I really like how you can easily see who is connected to the radio, what frequency they are using, mode and antenna selections.  Now you can easily tell if someone else is lurking on your radio.
  • Member ✭✭
    edited April 2019
    Mark, I'll echo the thanks for the quick update.  Nicely adapted to support multi-client.
  • Member ✭✭
    edited June 2020
    Nice work Mark. Well done.
  • Member, Super Elmer Moderator
    edited June 2020
    Nice Mark! I like the control surface support. Dave wo2x
  • Member ✭✭
    edited April 2019
    Thank you Mark, excellent work!
  • Member ✭✭✭
    edited April 2019
    Your really on the ball there Mark
  • Member ✭✭
    edited April 2019
    Syncing the slices of two different clients is the killer feature. It took one day for a 3rd party app to build ontop of the new possibilities of multiFlex. Can your legacy radio do that?
    Thanks to FlexRadio and Mark!
    Andy
    kU7T
  • Member ✭✭✭
    edited April 2019
    Thanks Mark...
  • Member ✭✭✭✭
    edited June 2020
    great Job Mark,
    I found a little bug I think, in the PGXL tune Amp unkey or tune drive Power  doesn't drop or increase  the tune power, maybe it is because I use the Radio tune button and not and not the FRStack button
    thank again Mark
    Bret
  • Member ✭✭
    edited June 2020
    Thanks Mark!
  • Member ✭✭✭
    edited April 2019
    I'll check into this issue when I get back to shack this weekend. Thanks for the report.
  • Member ✭✭✭
    edited April 2019
    I have updated FRStack to address bugs reported on the first release of V3 and improve the View All / Sync A & B Slice feature (Clients viewer). FRStack now binds to a client and you can open the Clients viewer / sync feature at the same time. 73
