FRStack Version 3.0.19.1 Released
Mark_W3II
Mark_W3II Member ✭✭✭
- Includes FRStack 2 features
- FRStack now support FlexAPI 3.0.19
- multiView support
- TX Band Settings view / edit
SmartSDR V3 supports multiple clients, you can bind FRStack to specific client in order to target client you wish to Tune, MOX or set TX Band Settings.
Sync Client Slices feature will keep clients' slices in sync with each other. The purpose is to allow the use of Maestro as a control surface for SmartSDR when co-located. You must not bind to a client for this feature to work.
Full release history can be found at http://www.mkcmsoftware.com/Flex/Index
  • John - K3MA
    John - K3MA Member ✭✭
    edited April 2019
    Mark, thank you for the quick update.  I really like how you can easily see who is connected to the radio, what frequency they are using, mode and antenna selections.  Now you can easily tell if someone else is lurking on your radio.
  • W9WLX_Chuck
    W9WLX_Chuck Member ✭✭
    edited April 2019
    Mark, I'll echo the thanks for the quick update.  Nicely adapted to support multi-client.
  • Bob G   W1GLV
    Bob G W1GLV Member ✭✭
    edited June 2020
    Nice work Mark. Well done.
  • David Decoons, wo2x
    edited June 2020
    Nice Mark! I like the control surface support. Dave wo2x
  • KF4HR
    KF4HR Member ✭✭
    edited April 2019
    Thank you Mark, excellent work!
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    edited April 2019
    Your really on the ball there Mark
  • Andy - KU7T
    Andy - KU7T Member ✭✭
    edited April 2019
    Syncing the slices of two different clients is the killer feature. It took one day for a 3rd party app to build ontop of the new possibilities of multiFlex. Can your legacy radio do that?
    Thanks to FlexRadio and Mark!
    Andy
    kU7T
  • RFord
    RFord Member ✭✭✭
    edited April 2019
    Thanks Mark...
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    great Job Mark,
    I found a little bug I think, in the PGXL tune Amp unkey or tune drive Power  doesn't drop or increase  the tune power, maybe it is because I use the Radio tune button and not and not the FRStack button
    thank again Mark
    Bret
  • N8FNR
    N8FNR Member ✭✭
    edited June 2020
    Thanks Mark!
  • Mark_W3II
    edited April 2019
    I'll check into this issue when I get back to shack this weekend. Thanks for the report.
  • Mark_W3II
    edited April 2019
    I have updated FRStack to address bugs reported on the first release of V3 and improve the View All / Sync A & B Slice feature (Clients viewer). FRStack now binds to a client and you can open the Clients viewer / sync feature at the same time. 73
