Why you need a PGXL?
Its quite fascinating reading through this thread.. noting the the feature that truly sets the PGXL apart from any other product is not front and center, rather how much power it puts out. Granted my PGXL, that is in my shack is one of the first, and was used to provide feedback to get the stable end product it has become.
Gang-- If you have a 2 amp shack.. you can replace both amplifiers with 1 PGXL. That is the key differentiator from the plethora of other LDMOS offerings. With its closest competitor in the new amp market only able to accept a feed from 1 radio at ~80% of the cost of a PGXL.. the value really begins to show. both can key down a solid 1500w in FT8/RTTY. only PGXL can do it while listening to another band at the same time you are transmitting. any other solution would take 2 amplifiers.
Considering that a PGXL can connect to a 6600/6700 Dual SCU radio creating a turnkey high power solution with 1 transceiver and 1 amplifier, allowing for all its features including full duplex, including integration of meters and such with SSDR-W/M is the value prop here.
This turnkey ecosystem works very well... and like all things flex puts out, there is no equivalent for it on the open market yet. If anyone in the community has any questions about PGXL, feel free to reach out to me, and I will be happy to answer your query.
For me, the value of a Flex made amp is in the integration with the Flex radios and software. There is just nothing out there that comes close to what Flex does over Ethernet/ DAX/CAT etc. I would be happy to pay a premium over what I paid for my KPA500 for a very high quality, less than full legal limit, smaller, quieter amp from Flex.1
Even you came to the conclusion that you still need amplifier redundancy in RTTY RU ;-) I'm personally pretty happy with the dual RF-kit setup I'm rolling with now, but a pair of PGXL's is where it's at. The real question I have: how offended would FRS be if any other amplifiers started speaking the PGXL SmartSDR TCP/IP APIs, sparsely documented as they presently are.
Hi BIll--
2 PGXL's... thats a lotta amp :-). Having an Acom, 4 alphas and 2 AL1200's at my disposal at RO convers that redundancy.. but The RF-kit amps are quite intriguing to me as well.. I know they are growing in popularity.
As far as FRS being offended by figuring out a way to use existing API's to make a product work in an integrated manner.. thats a question I cant answer.. I would hope they would welcome the ingenuity.0 -
I had one of the early release PGXLs (Serial # 8) and now I have a 2nd production run one.
Agree with Chris that you can replace 2 amps with it.
But what sets it apart for me is that it is a completely modern amp. Things like the vapor phase heatsink, color lcd, MEffA and ethernet and of course dual LDMOS are what do it for me.1 -
Bill FWIW, the second amp would be a stay in the game redundancy strategy rather than a functional workflow strategy, Tom K2SC/8P5A lectured on the emergence of equipment like this, and decisions to use/or not based on op scenarios, such as being in a contespedition situation if the amp goes.. can you stay in the game.. so in this case the second amp would be if the first fails.. to stay in the game.0
Must I remind all that the difference between 1K and 1.5 K. Is 1.76 dB. Not enough on FT8 to make a noticeable difference at the other end.1
NONSENSE... if they cant copy you because you are -24 then adding almost 2dB brings you to -22 where they can copy you...
Every watt helps when you are weak at the receiving end.2 -
From one Pat to another Pat,
You are correct. That power difference means squat. FT8 was specifically designed to be able to decode weak signals.
I use FT8 every day. Ive had many QSO's with stations that copy me at -24.with no problems.
My town is just 442' ASL and I use a small modest ground mounted Hustler 6BTV vertical. Power is 300 watts.
Every EME operator wishes they could easily find another 1.76dB advantage for their station.0
Not worth the extra cost, for me to duplicate what I have . Would cost me about 1700 dollars not worth the 1.76 dB.1
I think you are missing Howard's point. At some -db threshold level a FT8 will not be able to be received. But adding a couple of db could make all the difference. And as Bill mentioned, same situation as EME.
Most of the time I actually use 500 watts or less, and still work close to 100% of the stations that call me or I call. I generally see what SNR is being reported and then set power accordingly. Propagation has more to do with it all, then raw power.0
No I know what Howard is talking about.... there are more variables then just raw power.0
But that's not what you said in your earlier post that Howard replied to. You effectively said that a 500 watt difference wouldn't really matter. And Howard replied that sometimes it could make the difference between making a contact or not. And he's right.
You are correct that there are other variables, but don't say that 500 watts won't make an effective difference. Just because you can't (or won't) justify the extra cost doesn't mean that others shouldn't.1 -
Hello everyone, I followed with interest these discourses, rmon summarize, I just made my 250 em country in ft8 thanks to which, a good balance in Db between my reception and my TX it is useless to be heard if have not heard the answer.
An effective antenna, when have the possibility to place it, a high performance rx / tx (flex radio .... hi) and power to use reasonably with a good balance.
73, Janny0 -
Hi Mark, look I know what said, so not sure what context you are interpreting . You have to understand that my operating conditions are not Howard’s conditions. This is part of why I stated that one has to analyze all the variable, such as antenna type, gain, hight above the earth, propagation on any particular day, location of the person being worked, and the list goes on. Power is not everything in working any particular station. Just to double check that my comments had merit. I looked at my log for the last 9 months, about 2000 contacts and looked at the receiving station report of my signal. I only found 4 contacts worked that where -22 or less. 2 of which were at 100 watts, and the other 2 at 500 and 1000 watts. On the vast majority of other contacts operated over 80, 40, 20, 17, 15, 12 and 10 meters signal reports were between -18 and +19 dB SNR. There is one other factor we need to deal with. That is the correlation of comparing power dB with SNR dB. They do not necessarily track each other in a linear way. RX AGC and other factors on the receive side may skew the SNR. So that 1.76 dB power advantage may not show up on the RX end. And may not matter. If one is getting -24 sig report running 1500 watts chances are the end station will copy you even at only 1000 watts. Actually reality shows that under such conditions that propagation is marginal at best and even if you hypothetically increased to 2000 watts, it is simply Mother Nature over power. All this is based on my own data, my own operating conditions. You and Howard and all others doing what we do will all be different. There are no absolute answers as all are operating conditions are different and no solution will be the same for all.0
@Pat
I tend to like to pursue the very weak ones as those invariably are the interesting DX..
Probably 40% of my Q's are -22 receive or worse. They are usually the little guys in small countries, running **** antennas, using signal link type sound card interfaces on legacy radios. Hardly anyone far away gets back to them and their receive situations are so poor, that you need to be at least -16 for them to hear you.
I have a SteppIR Monster (13dBi) @85' about 600'ASL about a mile from the Pacific with an unobstructed view to the west. Running 1.5KW (albeit my SPE will only sustain 1.2KW),, I have an ERP in excess of 10KW. Yet still those weak but interesting Q's have a hard time copying me or anyone else.
So while there are many factors such as propagation, etc that weigh in on a successful Q, POWER HELPS A LOT
Howard, I do not disagree with you on that, I have also worked many of those type of stations. For myself, I do well with my Log at 42 feet and elevation of 480 feet. The 5000 foot mountain in back of me still gives me a fairly low take off angle. Enough to do Europe ok. But to work anyone on any band I need at least 2400 miles of range. So far on 80 meters I see a max range of about 9000 miles, even with a apex of only 30 feet. As for the other bands have done long path many times . To add, my reason for not going with the PGXL is mostly financial, balanced with acquired capability. Good luck on your DX quest....0
- 337 Community Topics
- 607 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 170 SmartSDR for Maestro and M models
- 401 SmartSDR for Mac
- 264 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 18 Aurora
- 188 FLEX-8000 Signature Series
- 913 Maestro
- 886 Genius Products
- 320 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 741 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 954 Third-Party Software
