6600 Power Up Issue
Cal  N3CAL
Cal N3CAL Member ✭✭
edited April 2019 in FLEX-6000 Signature Series
My 1 year old Flex 6600 has started to act up recently.  It will not power up (solid green power light) anytime a 10mhz external reference is connected to the back of the radio.  When power button is pressed it flashes green for 1-2 minutes then I get 1 red flash repeating.  Manual says it's a fan issue.   I removed all cables from back of radio to troubleshoot and noticed the radio would power up without any cables connected.  As soon as I hook up the external 10Mhz Ref it's back to 1 red flash???   My external ref appears to be working fine.  I have it hooked up to my shack computer as well via RS232 and it shows it locked and has 12-14 Sats in view.  When I have more time after work today I will Oscope the 10mhz and do some further troubleshooting.  For the time being the radio is booting on the internal TCXO.  Just curious if anyone else has seen this issue?
Cal/N3CAL
    edited April 2019
    I have converted this to a helpdesk ticket.
