TX EQ, Compression, etc. when using DAX?
David Salomon
When using DAX for digital, are all the TX adjustments disabled, i.e. no compression, DEXP, etc.?
In SSB mode, audio coming in from DAX will be processed by TX EQ, PROC, DEXP, etc.
When in DigU/DigL, and RTTY, the tx bandwidth controls function, but TX EQ, PROC, and DEXP are turned OFF.
So when running Digital modes, ALWAYS use the Digital input modes. (DigU, DigL, RTTY).
If you are using a voice Keyer or other audio source for voice modes, use SSB, am, fm, etc., and your audio source will be processed just like your Mic inputs are.1 -
Ken -
Thanks for the detailed answer. I was afraid of that. One of my use cases for the radio is to simultaneously use digital and voice, i.e. tell someone a digital message follows, then send the message. During my nets, this happens very often. Is there a way to automatically use one profile via DAX and another for the MIC input, which would solve my dilemma?
73 - David, AG4F0 -
DEXP is for killing noise around your MIC. don't need it for digital. Why run compression on digital don't need to blast the Ham your talking to with a distorted signal. Now the TX adjustments I could see that could be useful. my two cents.
I have not got use the new software yet.
Jim
WU5E
One work around would be to set your digital program up on one slice with auto-switch, and set up your mic on another slice. Then transmit SSB on one slice, and send your digital stuff on the other, both on the same frequency. Mute the digital slice, since you will hear it in the other.0
That's exactly what I need to do. I just tried it and it works perfectly.
Thanks much for the guidance!
73 - David, AG4F0 -
Another other advantage of doing it this way is that you can set the AGC and AGC-T differently for the Digital mode than you do for the voice mode.... i.e. you may wish to have the AGC OFF or FAST for the Digital mode and adjust it carefully to set the input to your digital program. But you may want to have the Voice mode slice set to MED or SLOW so you don't hear all the noise on the channel....
You can even set all this up and save it as a Global Profile "SSTV NET" or "MARS Digital NET" etc. then you only need to recall the global profile for your digital net.
Good luck.
Ken - NM9P0 -
So, you guessed correctly why I need to do this (MARS digital). I have two more questions for you. How do I set the AGC-T from SSDR (I know how to select FAST/MED/SLOW)? Is there a way to set the upper and lower receive filter values other than dragging with the mouse in the RX box or on the spectrum area? I'd like to set the RX filter to 100/3400 on both slices, and 3.3K is not an option for DIGU.
Thanks again.
David, AG4F0 -
And one more question...
I opened the profile export and selected all, but it's exporting only the memories, not all the other info. Why?
David, AG4F0 -
Well, I spoke too soon. It wasn't actually transmitting from slice B. Whichever slice I select as TX is the slice it transmits from, even is audio is coming from DAX. I looked around (a lot) trying to find an "auto-switch", but came up empty.0
Auto-switch is set up in the CAT Control panel. You can define each CAT port and assign it to a particular slice, and tell it whether to automatically switch atax to that slice whenever the cat tx command is issued on that port.... really slick. You adjust AGC-t in the slice flag, in the audio (speaker) tab. To find the AGC sweet spot, Start all the way right, and move it left until the noise just starts to drop. Go a little further on phone to have a quieter, but a little less sensitive band.0
Thanks again, Ken. I tinkered with it a bit and got it working. You're right, it is really slick. Every hour I spend with this rig I learn something new about it. Maybe by the end of 2018 I'll be completely up to speed.
73 - David, AG4F0 -
Alright, I must have missed one more thing. The rig switches to slice B and transmits, but then doesn't switch back to slice A. I have to manually push the TX button for slice A to return to voice ops. Am I missing something else?
David, AG4F0 -
That is the way it works. Unless you use a serial PTT somehow. Perhaps via a utility like DDUtil or FRStacks.0
Hi Ken, a related question. The Mic Dax signal is that before or after mic compression, DX or DX+ mic effect are applied? I am testing voice keyers (with Audacity) but my station is temporarily down so I cannot test this. I do not want double compression applied...:)
73 Kari SM0HRP0 -
The DAX Mic signal that you can record is tapped before the filters, EQ, and processing. It is clean, so that you can record it and play it back as though it was straight from your Mic. When you use the recording to transmit via the DAX TX feed, then the rig will process it, filter and EQ just as if it was coming from your Mic. You do not need to do any pre processing g, except you might want to use a very little bit of compression or leveling just to make sure that all of your voice Keyer levels are consistent.0
- 333 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 169 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
