Suddenly no reception on antenna one and no transmit on either, infinite SWR on TX
Suddenly I had no reception on antenna 1.  I switched my antenna (I only have one) to antenna 2 and now I had RX.  BUT when I hit the Tune function, the SWR's went off the chart and I had to shut down the radio.  I rebooted it and then tried to Xmit on antenna 2.  SWR's off the chart again.  No signal at all when I attach my antenna to Antenna 1.  I had not disconnected the antenna at the pass through, this just came out of the blue.  Any ideas?
The radio is a 6300 and the software is latest, 2.4.9.
Welcome!
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    edited April 2019
    Hi Russ
    A few things.
    First, can you check the antenna with another device like an analyzer or another radio?
    Can you do an SWR test to a dummy load?
    If you don't have any of the above, then I would export your profiles to save your settings and then do a radio reset.  And then, test again.
    If that doesn't work and you have confirmed the antenna and all jumper cables are ok, then it would be time to open a support ticket.
  • Member ✭✭
    edited March 2019
    For the receive part it could be a blown ESD diode but I don't think that affects TX.
  • Member ✭✭
    edited June 2020
    I had some RX weirdness like this earlier in the week, Saved my profiles, did a reset and everything was good.
    Zack N8FNR
  • Member ✭✭
    edited March 2019
    I found the problem, mostly operator error (the first place to look.....)  Thanks for the suggestions.
  • Member ✭✭
    edited March 2019
    Details, please.
  • Member
    edited March 2019
    I have a similar problem. Could you  share your solution?
    Frank Smith, WS1MH
