Swr plotting Graph
Ray has developed an App for that in our "Works with Flex" department.
http://k9dur.info/smartsdr_utilities.html
Look for SWR Plotter. I just ran this on my 160M vertical.
Mike...have you looked at SWRPlotter6K?...Google it.
Lou N2TU0 -
sounds good i will check it out thanks.0
ok thanks lou!0
But this is for Power SDR?0
I found it. I think you meant to give this link. http://k9dur.info/smartsdr_utilities.html0
A useful idea my last rig a FT2000 with the DMU was able to plot each band aiding me diagnosing antenna issues, learning about the changes in antennas with weather and so forth. I kept screen shots of the patterns of my antennas as a historic reference.
Yep.. I updated the link http://k9dur.info/smartsdr_utilities.html.0
I do that on my 160M vertical, as it varies as the ground freezes and thaws. It is amazing how much it moves.1
my original idea was to have it implemented in Version 3. not another program running in the background. I have tons of programs already up my desktop.
There are versions for both PowerSDR and 6xxx, I have used both by Ray, K9DUR.
The way FRS has designed the radio and the API's that go with the radio is to promote tools such as SWRPlotter and allow you to have them anywhere on your LAN and not just on one computer. We call this "Works with Flex". This is just some of the items and we are adding all the time: https://www.flexradio.com/works-with-flex/
The plot I posted above was done on a different computer than my normal Ham computer, well, because you can.
The Application Programmer Interface allows all hams to build the tools they need to go with the radio solution. FRS will continue to build up the core functionality of the radio with items like SmartLink and MultiFlex. Allow others to contribute is a great way to get tools quickly as other Hams can contribute and support the overall solution.
It wouldn't really make any sense to add this inside the SmartSDR application since we already have a wonderful solution provided by Ray, K9DUR.
Well I am sure many will agree or disagree but either way thank you for answering my post. n2mdx.0
We try to let everyone know what we are up to. Just some normal people working hard everyday.
I am a Technician by trade as well I totally understand.0
Yes, but would be nice to have on the front display of the M or Maestro
3 -
I use it, works great !0
Steve...the DMU forced you to screenshot everything . SWRPlotter6K allows you to print the graphs and do a 'light box' comparison. Neat feature!0
Thanks Lou reading I will be checking it out. 73
Steve
Dont forget to PayPal him a couple of bucks. I use his voice keyer all the time. Everything he does has worked well for me.
Roger
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 192 SmartSDR for Maestro and M models
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 983 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
