Swr plotting Graph
edited November 2019 in New Ideas
What about adding a SWR plotting program built in with antenna analyzers across the entire spectrum, on all bands with memory presets right off a drop down menu?
thanks mike n2mdx. :)
3 votes
In Review · Last Updated
Welcome!
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    edited April 2019
    Ray has developed an App for that in our "Works with Flex" department.
    http://k9dur.info/smartsdr_utilities.html
    Look for SWR Plotter.  I just ran this on my 160M vertical.
  • Company Adviser ✭✭
    Mike...have you looked at SWRPlotter6K?...Google it.
    Lou N2TU
  • Member
    edited March 2019
    sounds good i will check it out thanks.
  • Member
    edited March 2019
    ok thanks lou!
  • Member ✭✭
    edited March 2019
    But this is for Power SDR?
  • Member ✭✭
    edited March 2019
    I found it. I think you meant to give this link. http://k9dur.info/smartsdr_utilities.html
  • Member ✭✭
    edited March 2019
    A useful idea my last rig a FT2000 with the DMU was able to plot each band aiding me diagnosing antenna issues, learning about the changes in antennas with weather and so forth. I kept screen shots of the patterns of my antennas as a historic reference.
    edited March 2019
    Yep.. I updated the link http://k9dur.info/smartsdr_utilities.html.
    edited March 2019
    I do that on my 160M vertical, as it varies as the ground freezes and thaws.  It is amazing how much it moves.
  • Member
    edited April 2019
    my original idea was to have it implemented in Version 3. not another program running in the background. I have tons of programs already up my desktop. ;)
  • Member ✭✭✭
    edited April 2019
    There are versions for both PowerSDR and 6xxx, I have used both by Ray, K9DUR.
    edited March 2019
    The way FRS has designed the radio and the API's that go with the radio is to promote tools such as SWRPlotter and allow you to have them anywhere on your LAN and not just on one computer.   We call this "Works with Flex".  This is just some of the items and we are adding all the time:  https://www.flexradio.com/works-with-flex/
    The plot I posted above was done on a different computer than my normal Ham computer, well, because you can.
    The Application Programmer Interface allows all hams to build the tools they need to go with the radio solution.   FRS will continue to build up the core functionality of the radio with items like SmartLink and MultiFlex.   Allow others to contribute is a great way to get tools quickly as other Hams can contribute and support the overall solution.
    It wouldn't really make any sense to add this inside the SmartSDR application since we already have a wonderful solution provided by Ray, K9DUR.
  • Member
    edited March 2019
    Well I am sure many will agree or disagree but either way thank you for answering my post. n2mdx.
    edited March 2019
    We try to let everyone know what we are up to.   Just some normal people working hard everyday.  :)
  • Member
    edited March 2019
    I am a Technician by trade as well I totally understand.
  • edited March 2019
    Yes, but would be nice to have on the front display of the M or Maestro
  • Member ✭✭
    edited March 2019
    I use it, works great !
    edited March 2019
    Steve...the DMU forced you to screenshot everything . SWRPlotter6K allows you to print the graphs and do a 'light box' comparison.  Neat feature!
  • Member ✭✭
    edited March 2019
    Thanks Lou reading I will  be checking it out. 73
    Steve
  • Member
    edited March 2019
    Dont forget to PayPal him a couple of bucks.  I use his voice keyer all the time.  Everything he does has worked well for me.
    Roger
