6600M main tuning knob responsiveness
t ash
All of a sudden the responsiveness of rotating the main tuning knob is showing a slight delay. It also appears to not be a smooth tuning as it had been.
This is minor, but noticeable.
I had not noticed this previously, anyone else seen this?
Is the issue still there if you reboot the radio? Are there any other clients connected to the radio?
My VFO B knob is not turning smoothly. It also makes a slight grinding sound when the knob is turned. Something is wearing or binding on the encoder shaft. Flex has been notified of my issue. I am sending the radio back for a replacement encoder.0
Hi Joe, yes, dealing with a formal ticket is the way to go for hardware issues.0
Thanks Michael. Now that you mention it, this did not start until I hooked up an external 4K monitor. After disconnecting the monitor all appears to be normal.
TKS
Thornton0 -
Hi Joe, the Grinding could be the Encoder in the Radio or it could simply be the VFO B knob is just to far on the shaft and rubbing the case of the radio.
If you CAREFULLY remove the rubber cover from the circumference of the knob (BIG RUBBER BAND) there are a couple Alan set screws that you can loosen and pull the knob off the shaft a little bit and re-tighten them and see if it cures it, My Maestro did this when it was new and this is what fixed it
If it still has drag / grinding then you will need to send it in by doing a help ticket.
Yep, already done all of that stuff. There is something wrong with the encoder shaft. Flex has authorized a return for this issue. Thanks -Joe0
- 337 Community Topics
- 605 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 401 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 185 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 185 FLEX-8000 Signature Series
- 913 Maestro
- 885 Genius Products
- 319 Tuner Genius XL
- 116 Antenna Genius
- 281 Shack Infrastructure
- 197 Networking
- 137 Contesting
- 740 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 952 Third-Party Software
