Transmit menu Maestro SSB
Bill Carnett
Can't find transmit menu on Maestro. Go in to Menu....transmit...only see the screen that Lists at top "General" tune power Hardware ALC....next section ACC TX: TX Delay....at bottom is TX EQ. Cannot find the menu that allows control/adjusment of VOX, mic selection etc. Yeah, I'm sure it is something obvious...but cannot find it. Any directions? In instructions it say's select Transmit menu and go from there...but there is no there. Thanks Bill
Press in on the center knob on the speed/power control on the far right.
Mack
W4AX
Alpha Team0 -
This should help you out.
https://youtu.be/oT632iL5L3E 0 -
Thank you both! Much Mahalo. Will look at the video and work on it next time in shack! Aloha,Bill0
Hi Bill,
You found it, but look under the mic/speed power dual concentric control and you'll
see it says TX Menu.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 966 Maestro
- 938 Genius Products
