Transmit menu Maestro SSB
Bill Carnett
Bill Carnett Member ✭✭
edited April 2019 in Maestro
Can't find transmit menu on Maestro.  Go in to Menu....transmit...only see the screen that Lists at top "General"  tune power  Hardware ALC....next section ACC TX:  TX Delay....at bottom is TX EQ.  Cannot find the menu that allows control/adjusment of VOX, mic selection etc.  Yeah, I'm sure it is something obvious...but cannot find it.  Any directions?  In instructions it say's select Transmit menu and go from there...but there is no there.  Thanks  Bill
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Press in on the center knob on the speed/power control on the far right.
    Mack
    W4AX
    Alpha Team
    edited April 2019
    This should help you out. https://youtu.be/oT632iL5L3E
  • Bill Carnett
    edited March 2019
    Thank you both!  Much Mahalo.  Will look at the video and work on it next time in shack!  Aloha,Bill
  • N9VC
    N9VC Member ✭✭
    edited March 2019
    Hi Bill,
    You found it, but look under the mic/speed power dual concentric control and you'll
    see it says TX Menu.
