Transmit menu Maestro SSB
Bill Carnett
Can't find transmit menu on Maestro. Go in to Menu....transmit...only see the screen that Lists at top "General" tune power Hardware ALC....next section ACC TX: TX Delay....at bottom is TX EQ. Cannot find the menu that allows control/adjusment of VOX, mic selection etc. Yeah, I'm sure it is something obvious...but cannot find it. Any directions? In instructions it say's select Transmit menu and go from there...but there is no there. Thanks Bill
Press in on the center knob on the speed/power control on the far right.
Mack
W4AX
Alpha Team0 -
This should help you out.
https://youtu.be/oT632iL5L3E
Thank you both! Much Mahalo. Will look at the video and work on it next time in shack! Aloha,Bill0
Hi Bill,
You found it, but look under the mic/speed power dual concentric control and you'll
see it says TX Menu.
- 346 Community Topics
- 612 The Flea Market
- 7.9K Software
- 2 SmartSDR+
- 6.3K SmartSDR for Windows
- 409 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 21 Aurora
- 202 FLEX-8000 Signature Series
- 919 Maestro
- 891 Genius Products
- 453 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 754 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 973 Third-Party Software
