Transmit menu Maestro SSB
Bill Carnett
Can't find transmit menu on Maestro. Go in to Menu....transmit...only see the screen that Lists at top "General" tune power Hardware ALC....next section ACC TX: TX Delay....at bottom is TX EQ. Cannot find the menu that allows control/adjusment of VOX, mic selection etc. Yeah, I'm sure it is something obvious...but cannot find it. Any directions? In instructions it say's select Transmit menu and go from there...but there is no there. Thanks Bill
Press in on the center knob on the speed/power control on the far right.
Mack
W4AX
Alpha Team0 -
This should help you out.
https://youtu.be/oT632iL5L3E
Thank you both! Much Mahalo. Will look at the video and work on it next time in shack! Aloha,Bill0
Hi Bill,
You found it, but look under the mic/speed power dual concentric control and you'll
see it says TX Menu.
- 333 Community Topics
- 601 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 399 SmartSDR for Mac
- 263 SmartSDR for iOS
- 247 SmartSDR CAT
- 184 DAX
- 371 SmartSDR API
- 9.1K Radios and Accessories
- 17 Aurora
- 170 FLEX-8000 Signature Series
- 912 Maestro
- 52 FlexControl
- 880 Genius Products
- 318 Tuner Genius XL
- 116 Antenna Genius
- 279 Shack Infrastructure
- 196 Networking
- 137 Contesting
- 730 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 949 Third-Party Software
