HiRes Display of the M Models for Maestro
I'd love to see the Maestro in the future with the same HiRes Display as the M Models. Will this come true some time?
1 votes
In Review · Last Updated
  • VE3DZP
    VE3DZP Member ✭✭
    edited February 2019
    It is the same now, NO difference..
  • Ulrich Gonter-Linz, DG7NFX
    sure? The Website of FRS says something different...
  • VK7WH Winston
    VK7WH Winston Member ✭✭✭
    I believe the original Maestro’s were a lower resolution, but the later Mark 2 versions with the on/off button on the side have the same higher resolution displays as the 6400M & 6600M.
  • k3Tim
    k3Tim Member ✭✭✭
    edited May 2020
    Flex product spec from website:
    6x00M -   1920 x 1200
    Maestro - 1280 x 800
    For Maestro V1 versus V2  I believe display resolution did NOT change.
    _..--
    k3Tim
    edited April 2019
    They are different resolutions, but it is impossible to see the difference.  I have them both side by side.
    OK. Thanks.
  • KF4HR
    KF4HR Member ✭✭
    The resolution on my Maestro V1 looks just fine.  What's not to like? :)
  • Johan _ SE3X
    Johan _ SE3X Member ✭✭
    Having had V1, now V2, can't really say there is a difference. If there is, I just haven't noticed. Maestro resolution just ufb!
