displaying both SWR and PO at same time
is there a way, or a utility/addon, that will display both the power out and SWR simultaneously?
Welcome!
  • edited April 2020
    Put power on 1 meter and put swr on the second pan meter
  • Member ✭✭
    edited February 2019
    not sure what you mean.....I'm set up for SO2R on 6600, so I have Radio1/A on the A side and Radio2/B on the B side.....not running SSDR....looking to display it on the Maestro
  • Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator admin
    edited April 2019
    Yes, with FRStack, SmartSDR , and you can do it on the M models and the Auxillary Meters on the Maestro and M model.  Section 32.3.9 in the Maestro Manual.
  • edited April 2020
    Just hit the little meter icon on the maestro on the right side of display between the panadapters. You can also touch left meter on maestro and set it for power and touch right meter on maestro and set it for swr
  • Member ✭✭
    so you have to shrinh the panadapter to display it? I'm trying to add just SWR and I'm getting everything else, when I hit minus the first one it removes is the one I want to kepp !!!!
  • Member ✭✭✭
    here is what the meter panel looks like with FRStacks,,it is not showing anything as my radio is off.image
    You can have the right meter in Power and the Left meter in SWR.  You tap the meters to change the display.
    I assume you are talking about a Maestro or M model.  It is helpful if you say the radio or client you are trying to use.
  • edited April 2020
    No you have A on left and B on right. Just tap the meter on the maestro till you get the meter you want displayed. Tap the A meter till you see power. Tap the B meter till you see SWR.
  • Member ✭✭✭✭
    edited October 2019
    Using my 6600M in FT8 mode, I like to group the power, SWR and level meters together on the right-hand side of the screen.
    edited April 2019
    James, you may want to watch this video as well.
    https://www.youtube.com/watch?v=oT632iL5L3E&t=961s
