displaying both SWR and PO at same time
Jamie WW3S
is there a way, or a utility/addon, that will display both the power out and SWR simultaneously?
Put power on 1 meter and put swr on the second pan meter
not sure what you mean.....I'm set up for SO2R on 6600, so I have Radio1/A on the A side and Radio2/B on the B side.....not running SSDR....looking to display it on the Maestro0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYes, with FRStack, SmartSDR , and you can do it on the M models and the Auxillary Meters on the Maestro and M model. Section 32.3.9 in the Maestro Manual.0
Just hit the little meter icon on the maestro on the right side of display between the panadapters. You can also touch left meter on maestro and set it for power and touch right meter on maestro and set it for swr
so you have to shrinh the panadapter to display it? I'm trying to add just SWR and I'm getting everything else, when I hit minus the first one it removes is the one I want to kepp !!!!0
here is what the meter panel looks like with FRStacks,,it is not showing anything as my radio is off.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYou can have the right meter in Power and the Left meter in SWR. You tap the meters to change the display.
I assume you are talking about a Maestro or M model. It is helpful if you say the radio or client you are trying to use.
730 -
No you have A on left and B on right. Just tap the meter on the maestro till you get the meter you want displayed. Tap the A meter till you see power. Tap the B meter till you see SWR.
Using my 6600M in FT8 mode, I like to group the power, SWR and level meters together on the right-hand side of the screen.0
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsJames, you may want to watch this video as well.
https://www.youtube.com/watch?v=oT632iL5L3E&t=961s
- 246 Community Topics
- 488 The Flea Market
- 7.1K Software
- 331 SmartSDR for Mac
- 243 SmartSDR for iOS
- 222 SmartSDR CAT
- 163 DAX
- 348 SmartSDR API
- 8.6K Radios and Accessories
- 766 Maestro
- 41 FlexControl
- 733 Genius Products
- 255 Tuner Genius XL
- 85 Antenna Genius
- 229 Shack Infrastructure
- 153 Networking
- 120 Contesting
- 115 Amateur Radio Interests
- 813 Third-Party Software
