Flex 6600m. USB
Jimmy Collis
Jimmy Collis Member
edited December 2019 in FLEX-6000 Signature Series
Is it possible to use USB on back of 6600m to go directly from USB from radio straight to the PC to work wsjtx program ft8 and not use smart sdr I'm using USB to female serial from 6600m then I'm connecting Male serial to USB to plug into computer cant get to work I want to work ft8 just threw 6600m and PC just like a kenwood or icom no smart sdr at all thanks for any help
    edited April 2019
    Hi Jimmy
    No.  There is no Audio on the USB connector so you can't do it that way.    Do it the old fashion would be a step backwards.
    I see you are having issues with WSJTx.  Have you tried using SliceMaster to get things working?
    This video might help you out to get it working the way it was designed to work.
    https://www.youtube.com/watch?v=_ww8CcGNAzg
  • Craig_KØCF
    Craig_KØCF Member ✭✭✭
    edited January 2019
    You must connect the 6600M to the computer with an Ethernet cable. Then run SmartSDR CAT and SmartSDR DAX on the computer to provide com ports for rig interface and audio channels to the radio respectively. Please see the SmartSDR manual for instructions on setting both CAT and DAX. Note that there is a separate CAT manual available for download as well.
    This is the beauty of Flex radios: No audio or CAT cables are required to interface digital mode software. It's all done with virtual cables inside the PC.
  • Ted  VE3TRQ
    Ted VE3TRQ Member ✭✭✭
    And I will add that with an "M" model, you do NOT need to run SSDR. You need to install it because that's how you get Cat and Dax, but once installed, just start Cat and Dax (after configuring, of course) by themselves and allow the "M" front panel to control aspects of the radio that wsjt-x cannot control (i.e. bandwidth, filters etc).
