SO2V RTTY with N1MM+ on 6600
Lawrence Libsch
I have a single antenna, so cannot do SO2R. I am unable to get my SO2V setup to TX on slice B with my present N1MM+ setup. I need help properly setting up slice B so it can TX. Using v2.4.9 and very recent version of N1MM+. I've spent a lot of time with articles in the community, but none seem to address this specifically and in detail. I've also read the N1MM+ wiki on SO2V w/o finding a solution there. Would really appreciate a reply from someone able to provide detailed instructions for a working installation. Spent lots of contest hours working SO2V with the K3. Would like to have this capability with the 6600. Larry, K4KGG
Hi Larry
I only have a moment, but why not set up your 6600 as SO2R?
You will need to set up CAT port for both A and B slices and then in N1MM set those as 2 unique radios.
See if this document helps you out: https://www.flexradio.com/downloads/flex-6700-so2r-configuration-n1mm/
Even though it says Flex 6700, the setup is identical.
Mike0 -
That's what I ended up doing,,, setting up as SO2R, MMTTY, & N1NM... I had **** trying to do So2V...
Hi Mike, Cosmos,
Thanks very much for your replies.
If I don't have a second antenna, how do I prevent transmitting into my radio with SO2R?
Larry, K4KGG
Just continue to use Ant 1 for the 2nd Slice.1
I'll give it a try. Thanks.
Larry, K4KGG
- 657 The Flea Market
- 438 SmartSDR for Mac
- 203 DAX
- 385 SmartSDR API
- 52 Aurora
- 296 FLEX-8000 Signature Series
- 969 Maestro
- 944 Genius Products
- 467 Remote Operation (SmartLink)
- 809 Peripherals & Station Integration
