My 6300 will no longer start - message "no radio found
VA6FH
VA6FH Member ✭✭
My 6300 stopped communicating with my computer - using version 2.3.9 but cannot upgraded nor downgrade
  • AH0U
    AH0U Member
    edited June 2019
    Turn off the radio AND unplug power then try to restart
  • VA6FH
    VA6FH Member ✭✭
    edited January 2019
    I did that to the radio, the router, the power supply  and the computer … no luck. Thanks
  • AH0U
    AH0U Member
    edited June 2019
    Didn’t t realize you were using a router... have you tried connecting the radio directly to the computer??
  • VA6FH
    VA6FH Member ✭✭
    edited January 2019
    The router is for the wireless connection from the computer to the outside world. The is a CAT5 connection from the radio to the computer.
  • DaveC
    DaveC Member ✭✭
    edited December 2018
    Have you tried plugging the radio into the router instead of the computer?
  • Larry _ NY8T
    Larry _ NY8T Member ✭✭✭
    Look at any software firewall program that may be blocking it.
  • VA6FH
    VA6FH Member ✭✭
    No … I have never had to do that before … I do have access to the internet from that computer,
  • DaveC
    DaveC Member ✭✭
    When I first got my 6300, There was an update that caused my radio to not connect directly to my computer, but it would connect via a router. Had something to do with how the IP addresses are assigned.
  • N9VC
    N9VC Member ✭✭
    edited January 2019
    Is it possible to try another computer?
  • Rich McCabe
    Rich McCabe Member ✭✭✭
    What IP address does your PC have? Are you running static on either?
  • VA6FH
    VA6FH Member ✭✭
    I am doing that now ...
  • VA6FH
    VA6FH Member ✭✭
    edited January 2019
    Auto assign.
  • VA6FH
    VA6FH Member ✭✭
    edited January 2019
    I thank you all for your help … I moved the radio software to another computer and it seems to be working very well. I guess that I have some sort of wireless/connectivity problem that I need to sort out, but for now … Thanks … Don
  • Pat N6PAT
    Pat N6PAT Member ✭✭
    Don,
    You might want to check your firewall settings. I use Avast security software and every so often it blocks my radio and I have to reset the firewall parms.
  • Rich McCabe
    Even though its on Auto assign (DHCP) you would want to check and see what IP address the PC is getting. Just because it is asking for an IP address does not mean it is getting one.
