Need the latest SmartSDR and Power Genius Software?
SmartSDR v3.1.12 and the SmartSDR v3.1.12 Release Notes. | SmartSDR v2.6.2 and the SmartSDR v2.6.2 Release Notes.
SmartSDR v1.12.1 and the SmartSDR v1.12.1 Release Notes. | Power Genius XL Firmware v3.4.16. | Power Genius XL Utility v2.2.10.
MOX button as "ordinary" PTT...
Hi All...
Is it possible to use the MOX button in SmartSDR as a ordinary PTT-button... TX when it's pushed, and hold. Back to RX when it's released.
Is this something that is achievable?
(SmartSDR for iOS has it...)
73 de Adde, SM0SHG
73 de Adde, SM0SHG
- 70 Community Topics
- 1.9K New Ideas
- 120 The Flea Market
- 5.4K Software
- 4.9K SmartSDR for Windows
- 35 SmartSDR for Maestro and M models
- 87 SmartSDR for Mac
- 144 SmartSDR for iOS
- 150 SmartSDR CAT
- 69 DAX
- 279 SmartSDR API
- 7.1K Radios and Accessories
- 5.8K FLEX-6000 Signature Series
- 557 Maestro
- 14 FlexControl
- 723 FLEX Series (Legacy) Radios
- 153 Power Genius Products
- 119 Power Genius XL Amplifier
- 12 Power Genius Utility
- 22 Tuner Genius
- 41 Shack Infrastructure
- 22 Networking
- 89 Remote Operation (SmartLink)
- 50 Contesting
- 128 Peripherals & Station Integration
- 62 Amateur Radio Interests
- 405 Third-Party Software
You can even have this work as a remote foot switch by connecting to the pins 7 and 8 on a serial port.
Cool little utility.
Here is the Flex community discussion https://community.flexradio.com/flexradio/topics/push-to-vox-version-1-0-0-is-now-available
73's
Bret
WX7Y
BTW, the update to v1.0.2 is fairly recent. While working on Slice Master 6000, I found a couple of bugs in the radio discovery code that I thought were worth fixing. I would have mentioned it in the Push to VOX thread, but the lack of activity there had me thinking that either nobody was using it or that it was working perfectly for everyone
Thanks again for the little app
73's
Bret
WX7Y
Using the built in Serial Port or USB serial cable COM port, set up in the CAT programming for PTT I have discovered the Foot switch and manual Mic key work great in my station just by shorting Pins 7 and 8.
I'm sure this is in the book but who reads the book hi hi and other programs use this same setup but having this work Remote with out another peace of software to load is ideal for me.
73's
Bret
WX7Y
How is the delay?
73 de Adde
73's
Bret
Thanks a lot
Bret
WX7Y
Good feedback guys, enjoyed reading this, will give it ago myself.
Kev
But will give the solution below a go.
Kev
Bret- I really want to figure this out and make it work. I don't yet have a microphone so was thinking USB but really could go anyway. I really want a physical PTT mechanism so I don't have to move the mouse or hit spacebar...
My question is:What microphone are you using?
I get using the CAT port - just curious about the physical hookup - What is your manual mike key/PTT? Your answer implies that you've built an interface via a serial port into the USB and shorted pins 7&8. what mic have you converted to Serial? Or is there one I'm not aware of?
Thanks!
as far as the Microphone it is also very easy and I have tried many different USB sound card interfaces and have settled on the Shure X2U USB XLR Microphone adapter.
I run this with my Heil PR-40 and audio is superb.
Don't waist your money on the purple Heil USB XLR (not enough audio out) or other USB XLR cable adapter they are very poor audio quality compared to the SHURE X2U adapter and a waist of Money.
Here is a link on Amazon, https://www.amazon.com/Shure-X2U-XLR-to-USB-Signal-Adapter/dp/B001PPXFAG/ref=sr_1_6?ie=UTF8&qid=....
Then you can do as I did and just run your SHURE PR-40 (or what ever XLR MIC your running) MIC profile using the PC Mic selection, sounds almost as good as running on the Balanced audio connection.
You pay a bit more for this quality device but it is well worth it.
This will give you OUTSTANDING TX Audio on the FLEX6700 or FLEX6600 radio's and I'm sure the other 6xxx radio's running Remote.
Hope this helps.
73's
Bret
WX7Y
Tnx
Dave
N6XVZ
