flex 6600 so2r setup - Non- Tx Radio Muted
John Kludt
Setting up Flex 6600 and Maestro for SO2R with N1MM Think I have followed all the directions but/and the non-Tx slice is muted when I am just listening on the TX slice. Kind of defeats the whole purpose. I am sure this is operator error - what did I miss? Running current version of N1mmLogger+ and SmartSDR 2.4.9, win 7
Are you running any other third party programs? Stacks has an option to mute all slices but the TX one.
Do you have OTSRP configured to work with N1MM as well?0
David,
Nothing else - Chrome but that is it.0 -
When I look at SmartCat is see (O) SO2R Flex, Serial:Com 12 Slices A/B, Process N1MMLogger0
Couple of things to check.
N1MM+ is in SO2R mode.
N1MM+ has OTSRP configured and you picked the SmartCAT COM port for it.
N1MM+ is restarted after changing any COM-related settings.
Flex is configured for full duplex.
Volume of the other slice is properly adjusted (not at 0)
N1MM+ tilde key switch working...
Andy
KU7T1 -
Never mind - PICNIC problem. I did not realize that the tilde key not shift-tilde is a toggle that mutes the non-TX receiver. Somehow that got toggled to the "Mute non-Tx rcvr" side of things. Once I figured that out, one push, problem resolved! So everything is working exactly as designed. Hopefully my dumb user error for the week,0
- 378 Community Topics
- 117 SmartSDR+
- 37 Aurora
- 946 Maestro
- 923 Genius Products
