How to Sync a Flex6xxx VFO to an Icom/Kenwood/Elecraft Radio VFO Tuning Same ... Any Software/Box o
Michael Aust
How to Sync a VFO Flex6xxx to an Icom/Kenwood/Elecraft Radio VFO Tuning Same Frequency ... Any Software/Box out there that does this ?
Want the Flex to be the Master Radio and the other rig VFO to follow the Flex
Michael
I'm pretty sure you can do this with HRD V5 (and may V6). I remember testing this years ago when I had a TS480 on my remote base and my Flex 3000 locally.
Mike va3mw
Found this, wondering if this would work ? A Non-PC solution - Remoteqth.com
https://remoteqth.com/arduino-band-decoder.php
Not sure if Flex6xxx talks same protocols as Kenwood, etc ?
https://www.youtube.com/watch?v=9_xMEbW8z28
I own some RemoteQTH stuff (more than I need). It works. Don't forget, your 6000 series radio has a built in BCD as well.
Does BCD from th Flex send more than just Band Data, does it include Frequency Data.
Think the RemoteQth Band Decoder can take BCD input ( not sure if it's same as Kenwood's BCD data - anyone know answer ? and drive the other radio, Icom or
possibly the Icom drive the Flex6xxx radio.
Depends which is Master and which radio is **** since think it is not bi-directional
( A seen in Youtube Video )
Similar to zero-beating "syncing" a Viking II to an HQ-170?
Sorry, couldn't resist.0 -
Yes. All 6000 radios can stream, Kenwood, CI-V, Yaesu or BCD ... at the same time.
http://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/
Very very flexible
I'll second the DX Lab Suite Commander software. My Yaesu FTDX-1200 tracks my 6500 via the software.
73 - Gary W4EEY
I think you may be able to use DDUtil for that. I used to use another utility to sync my 1500 to my 6500 about two or three years ago, but I cannot remember what I used. It allowed me either to make the 1500 follow the 6500, the 6500 follow the 1500, or both follow each other, depending upon which boxes were clicked. It was really slick.0
Michael - I have written a program that does exactly what you need. I emailed you download instructions.
73, Wayne
K4ELO
need sync N1MM+ and FLEX 6500 and KENWOOD TS-2000
This is posible?
73s EC5AN0 -
Yes. TS2000 on one hardware serial port for radio 1 and the 6500 set up as Radio 2. Make sure you do an SO2R setup.0
no so2r setup.
online airspy hf+ cat calico is kenwood ts-2000 and flex 6500
Thaks Michael.
my setup interested is sync N1MM+ and FLEX 6500 and KENWOOD TS-2000
I'm not sure what you are trying to do. Is it to have a 6500 track the VFO on a TS2000 so they stay in sync using N1MM?
If that is correct, can I ask why and I don't think you can, but you can ask that in the N1MM+ users group.
If you wish to us both the TS2000 and the 6500 while connected to N1MM for a contest, then you need to so an SO2R setup.
Let me know what you are thinking.
Keeping 2 radios in sync is not something N1MM does. I know that DXLax has that exact feature. May not be as convenient in a contest, but that would be doable. Any KU7T0
- 332 Community Topics
- 599 The Flea Market
- 7.9K Software
- 6.2K SmartSDR for Windows
- 398 SmartSDR for Mac
- 262 SmartSDR for iOS
- 247 SmartSDR CAT
- 181 DAX
- 370 SmartSDR API
- 9.1K Radios and Accessories
- 16 Aurora
- 912 Maestro
- 52 FlexControl
- 873 Genius Products
- 312 Tuner Genius XL
- 115 Antenna Genius
- 278 Shack Infrastructure
- 196 Networking
- 135 Contesting
- 727 Peripherals & Station Integration
- 137 Amateur Radio Interests
- 948 Third-Party Software
