How to Sync a Flex6xxx VFO to an Icom/Kenwood/Elecraft Radio VFO Tuning Same ... Any Software/Box o
Michael Aust
Michael Aust Member ✭✭
How to Sync a VFO Flex6xxx to an Icom/Kenwood/Elecraft Radio VFO Tuning Same Frequency ... Any Software/Box out there that does this ?
Want the Flex to be the Master Radio and the other rig VFO to follow the Flex
  • Mike va3mw
    Mike va3mw Member ✭✭
    edited February 2018
    Michael
    I'm pretty sure you can do this with HRD V5 (and may V6).  I remember testing this years ago when I had a TS480 on my remote base and my Flex 3000 locally.
    Mike va3mw
  • Michael Aust
    edited July 2017
    Found this, wondering if this would work ? A Non-PC solution - Remoteqth.com
    https://remoteqth.com/arduino-band-decoder.php
    Not sure if Flex6xxx talks same protocols as Kenwood, etc ?
    https://www.youtube.com/watch?v=9_xMEbW8z28
    Mikeimage
  • Mike va3mw
    I own some RemoteQTH stuff (more than I need).  It works.  Don't forget, your 6000 series radio has a built in BCD as well.
  • Michael Aust
    edited July 2017
    Does BCD from th Flex send more than just Band Data, does it include Frequency Data.
    Think the RemoteQth Band Decoder can take BCD input ( not sure if it's same as Kenwood's BCD data - anyone know answer ? and drive the other radio, Icom or
    possibly the Icom drive the Flex6xxx radio.
    Depends which is Master and which radio is **** since think it is not bi-directional
    ( A seen in Youtube  Video )
  • Clay N9IO
    Clay N9IO Member ✭✭✭
    edited August 2019
    Similar to zero-beating "syncing" a Viking II to an HQ-170?
    Sorry, couldn't resist.
  • Mike va3mw
    edited July 2017
    Yes.  All 6000 radios can stream, Kenwood, CI-V, Yaesu or BCD ... at the same time.  :)
    http://www.flexradio.com/downloads/usb-cable-interface-guide-pdf/
    Very very flexible
  • Gary Wise
    Gary Wise Member ✭✭
    edited July 2017
    I'll second the DX Lab Suite Commander software. My Yaesu FTDX-1200 tracks my 6500 via the software.
    73 - Gary W4EEY
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    I think you may be able to use DDUtil for that. I used to use another utility to sync my 1500 to my 6500 about two or three years ago, but I cannot remember what I used. It allowed me either to make the 1500 follow the 6500, the 6500 follow the 1500, or both follow each other, depending upon which boxes were clicked. It was really slick.
  • K4ELO
    K4ELO Member ✭✭
    edited December 2019
    Michael - I have written a program that does exactly what you need.  I emailed you download instructions.
    73, Wayne
    K4ELO
  • HAM BUY
    HAM BUY Member
    edited April 2019
    need sync N1MM+ and FLEX 6500 and KENWOOD TS-2000
    This is posible?
    73s EC5AN
    edited October 2018
    Yes. TS2000 on one hardware serial port for radio 1 and the 6500 set up as Radio 2. Make sure you do an SO2R setup.
  • HAM BUY
    HAM BUY Member
    edited October 2018
    no so2r setup.
    online airspy hf+ cat calico is kenwood ts-2000 and flex 6500
    Thaks Michael.
    my setup interested is sync N1MM+ and FLEX 6500 and KENWOOD TS-2000
    edited October 2018
    I'm not sure what you are trying to do.  Is it to have a 6500 track the VFO on a TS2000 so they stay in sync using N1MM?
    If that is correct, can I ask why and I don't think you can, but you can ask that in the N1MM+ users group.
    If you wish to us both the TS2000 and the 6500 while connected to N1MM for a contest, then you need to so an SO2R setup.
    Let me know what you are thinking.
  • Andy - KU7T
    Andy - KU7T Member ✭✭
    edited October 2018
    Keeping 2 radios in sync is not something N1MM does. I know that DXLax has that exact feature. May not be as convenient in a contest, but that would be doable. Any KU7T
