Slice master does't work for CW Skimmer
Henry SungHenry Sung Member
edited May 2019 in SmartSDR for Windows
 Hi,
I'm now using CW Skimmer with SDR-Bridge.
It works so well however I try to use Slice master instead of SDR-Bridge.
Unfortunately it dose not work with CW Skimmer.
The error message is "Audio device for DAXIQ channel is missing. daxiq=1"
Is there anyone who knows why this message is happen ?
 Henry
  • Mike-VA3MWMike-VA3MW FlexRadio Employee, Community Manager admin
    edited April 2019
    Do you have an IQ stream assigned to DAXIQ 1?
  • Henry SungHenry Sung Member
    edited October 2018
    Yes, IQ stream is properly working. As I mentioned with SDR-Bridge CW skimmer works no problems.
    edited April 2019
    Hi Henry, just wanted to make 100%.  I assume you have restarted DAX just in case there was an issue with the connection to Slice Master?
    I have had it working just fine for me with only SliceMaster and SliceMaster auto configured it.
  • K1DBOK1DBO Member ✭✭
    edited October 2018
    Henry,
    The problem is with your DAXIQ driver installation. That error message is Slice Master's way of telling you that your 'DAX IQ RX 1' driver is missing.
    --Don
  • Jay NationJay Nation Member
    edited May 2019
    I'm still fixing these DAX IQ errors, for anyone that needs help, in the #Flexradio IRC channel.
    the link is in my signature. If your willing to have it fixed, I'm willing to fix it. BTW, it's a PC/OS problem, not a SmartSDR problem. Come see me in the channel for more information.
        #FlexRadio IRC chat
    For real-time discussions
            SDRgadgets
    User created documentation.
               Volunteer!!
             73, Jay - NO5J
    edited October 2018
    I tried to uninstall all dax drivers on CMD line and re-install again. But I can not fix of this issue.
