Issues with SmartLink in SmartSDR v2.4.9
WX7Y
Member ✭✭✭✭
Issues with SmartLink in SmartSDR v2.4.9 radio chooser with DAX and CAT not finding the radio, SmartSDR seems fine.
Did you try manually connecting to both the CAT and DAX?0 -
Strange, v2.4.9 doesn't show up in my 6400M, only in SmartSDR also.
You have to login into each program individually: SSDR, SDR-Cat, SDR-DAX
Andreas, N6NU0 -
something was out of sink, when I connected to each program individually SmartSDR would logout of smartlink and un-register it self and DAX and CAT would show the radios in the chooser then if I reconnected the radio the other 2 would not show up in Radio chooser.
I finally got both radio's in sync but had to un-register and log-out ALL three programs and both radio's with ALL three radio chooser up and re-logged in and on the desk top I only had to resister the Radio's SmartLink on SmartSDR and the others followed suit.
I think the trick is to un-register the radio's from SmartLink then do the upgrade then login and re-register smartlink after the Update.
Thanks for the response's
73's
Bret
WX7Y
The issue here is, that SmartSDR stops working if I have registered SmartLink.
It just crashes on my Windows 7 notebook, I have to terminate it with my task manager.
If I unregister, all is fine.
I'll open a ticket.
73, Alex - DH2ID0 -
I have tested new 2.4.9 in SmartLink mode and with OpenVPN:
really perfect, even with Latency up to 200ms and more ! i get FT8 QSO's without trouble
Win10
DIGI -> JTDX ->https://www.jtdx.tech/en/
F6700
Router - ASUS AC-3200
KUDOS !0 -
Sorry, the issue seems not to be SmartLink, but my batch file!
I start all programs with a compiled batch file, containing the line:
"start SmartSDR.exe --serial=XXXX-XXXX-XXXX-XXXX"
This seems to crash SSDR. I've opened a ticket.
My workaround:
1. Start SSDR manually - this works on all PC's and notebooks and OS 7-10
2. Start all the programs with a compiled batch file:
MiniDeluxe, JTAlertX with WSJT-X, HRDLog,Stacks and GridTracker
I will compile more batch files to start other program constellations.
73, Alex - DH2ID0
- 107 SmartSDR+
- 427 SmartSDR for Mac
- 256 SmartSDR CAT
- 942 Maestro
