Issues with SmartLink in SmartSDR v2.4.9
WX7Y
WX7Y Member ✭✭✭✭
Issues with SmartLink in SmartSDR v2.4.9 radio chooser with DAX and CAT not finding the radio, SmartSDR seems fine.
  • Jim Gilliam
    Jim Gilliam Member ✭✭
    edited September 2018
    Did you try manually connecting to both the CAT and DAX?
  • Lynwood Wilson
    Strange, v2.4.9 doesn't show up in my 6400M, only in SmartSDR also.
  • Andreas Junge
    Andreas Junge Member ✭✭
    edited April 2019
    You have to login into each program individually: SSDR, SDR-Cat, SDR-DAX
    Andreas, N6NU
  • WX7Y
    WX7Y Member ✭✭✭✭
    edited June 2020
    something was out of sink, when I connected to each program individually SmartSDR would logout of smartlink and un-register it self and DAX and CAT would show the radios in the chooser then if I reconnected the radio the other 2 would not show up in Radio chooser.
    I finally got both radio's in sync but had to un-register and log-out ALL three programs  and both radio's with ALL three radio chooser up and re-logged in and on the desk top I only had to resister the Radio's SmartLink on SmartSDR and the others followed suit.
    I think the trick is to un-register the radio's from SmartLink then do the upgrade then login and re-register smartlink after the Update.
    Thanks for the response's
    73's
    Bret
    WX7Y
  • DH2ID
    DH2ID Member ✭✭✭
    The issue here is, that SmartSDR stops working if I have registered SmartLink.
    It just crashes on my Windows 7 notebook, I have to terminate it with my task manager.
    If I unregister, all is fine.
    I'll open a ticket.
    73, Alex - DH2ID
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    I have tested new 2.4.9  in SmartLink mode and  with OpenVPN:
    really perfect, even with Latency up to 200ms and more ! i get FT8 QSO's without trouble
    Win10
    DIGI -> JTDX ->https://www.jtdx.tech/en/
    F6700
    Router - ASUS AC-3200
    KUDOS !
  • DH2ID
    DH2ID Member ✭✭✭
    Sorry, the issue seems not to be SmartLink, but my batch file!
    I start all programs with a compiled batch file, containing the line:
    "start SmartSDR.exe --serial=XXXX-XXXX-XXXX-XXXX"
    This seems to crash SSDR. I've opened a ticket.
    My workaround:
    1. Start SSDR manually - this works on all PC's and notebooks and OS 7-10
    2. Start all the programs with a compiled batch file:
        MiniDeluxe, JTAlertX with WSJT-X, HRDLog,Stacks and GridTracker
    I will compile more batch files to start other program constellations.
    73, Alex - DH2ID
