FT8 randomly stops transmitting
2»
  • DV
    DV Member ✭✭
    edited September 2018
    Yes Brian, and setting up the COM port using FlexVSP.  Haven't seen a lockup TX since doing that.
  • Brian VK3MI
    Brian VK3MI Member ✭✭
    Thanks Doug. I will try doping the same. Hopefully the bug in the WSJT-X driver for the Flexradio 6xxx series will eventually be fixed - let's see what 1.10 (now in Beta) does.
  • Ray - K6LJ
    Ray - K6LJ Member ✭✭
    Hi I recently had very similar issues with the wsjt-x when it suddenly stopped transmitting. I also had some cat errors when trying to change frequency. I'm not sure if you all have looked at your dax drivers.
    I had noticed that there was a recent windows upgrade. My dax drivers looked like this
    This is the way it is supposed to look. After much uninstalling and manual removal and installation of DAX files I got it to look like this and my issues went away
    By the way the first pic wa after I had removed a bunch of ghosted and other DAX drivers. They are supposed to look like the correct list and be in the same order. If some have gone to a new computer and installed Smart DSR this could give you a fresh set of correct drivers.
    73 ray
  • rgracer
    rgracer Member ✭✭
    edited November 2018
    I have an odd situation. I had no problems with setting up my 6300 on FT8. Using DAX and Slice-Master. I want to use my iPad, so I set up Parallels Access. It was fine for one evening and then it stopped transmitting only with the iPad. On the computer itself, it works very well. I noted that the PTT is triggered, but there is no audio. Any ideas? Interesting, I changed to JUMP desktop and it works fine. Parallels runs the apps through their software; Jump is a mirror
  • Larry Betz
    Larry Betz Member
    edited December 2018
    I've got the same problem with a new icom 7300 and running a mac mini
  • Larry Betz
    Larry Betz Member
    I've got the same problem with a new icom 7300 and running a mac mini and I'm running the news version
  • ve7jai
    ve7jai Member, Unconfirmed
    [{"insert":"I have almost same problem when I am go with high power WSJTX switched of and say reconfigure. Think RF interference is doing something on computer \n\n"}]
