Can I create a com port without smartSDR running.I would like to use my 6400M as a stand alone.
Albert Schneebeli
How do I create a com port with out smartsdr running?
Yes. Assuming you have installed SmartSDR on your computer you can use SmartSDR Cat application to create a COM port without running SmartSDR.0
I assume initial question was “ can I utilize COM port without SSDR running”
Create - yes
Utilize without activated at least one slice - not0 -
To be clear, you can create COM ports using SmartSDR CAT without needing to have SmartSDR running on your computer. You can also use the COM ports with third party applications such as N1MM logger, without running SmartSDR. SmartSDR CAT has to be running. Simply have your 6400M turned on with at least one active slice on the panadapter. I do it all the time with N1MM + and DX Labs commander and DX Keeper apps.
Joe is correct, DAX and CAT are not in SSDR, they are seperate programs.0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 769 Maestro
- 42 FlexControl
- 729 Genius Products
- 394 Power Genius XL Amplifier
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
