Can I create a com port without smartSDR running.I would like to use my 6400M as a stand alone.
Albert Schneebeli
Albert Schneebeli Member ✭✭
edited February 2019 in FLEX-6000 Signature Series
How do I create a com port with out smartsdr running?
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    Yes. Assuming you have installed SmartSDR on your computer you can use SmartSDR Cat application to create a COM port without running SmartSDR.
  • Sergey R5AU
    Sergey R5AU Member ✭✭
    edited September 2018
    I assume initial question was “ can I utilize COM port without SSDR running”
    Create - yes
    Utilize without activated at least one slice - not
  • Joe N3HEE
    Joe N3HEE Member ✭✭
    To be clear, you can create COM ports using SmartSDR CAT without needing to have SmartSDR running on your computer.  You can also use the COM ports with third party applications such as N1MM logger, without running SmartSDR.  SmartSDR CAT has to be running.  Simply have your 6400M turned on with at least one active slice on the panadapter.  I do it all the time with N1MM + and DX Labs commander and DX Keeper apps.
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    Joe is correct, DAX and CAT are not in SSDR, they are seperate programs.
