Can I create a com port without smartSDR running.I would like to use my 6400M as a stand alone.
Albert Schneebeli
How do I create a com port with out smartsdr running?
Yes. Assuming you have installed SmartSDR on your computer you can use SmartSDR Cat application to create a COM port without running SmartSDR.0
I assume initial question was “ can I utilize COM port without SSDR running”
Create - yes
Utilize without activated at least one slice - not0 -
To be clear, you can create COM ports using SmartSDR CAT without needing to have SmartSDR running on your computer. You can also use the COM ports with third party applications such as N1MM logger, without running SmartSDR. SmartSDR CAT has to be running. Simply have your 6400M turned on with at least one active slice on the panadapter. I do it all the time with N1MM + and DX Labs commander and DX Keeper apps.
Joe is correct, DAX and CAT are not in SSDR, they are seperate programs.0
- 113 SmartSDR+
- 921 Genius Products
- 124 Antenna Genius
