Diversity on 6600
Neil Rogers
I'm looking at the 6600 as my next radio, connectivity and ability to monitor several digi streams concurrently.
I am looking at running 2 aerial system on the same band monitoring he same band 6m yagi & Big Wheel. Products like the anan range allows grounding on the 2nd ADC on tx to stop overdriving. Does the 660 support this feature
The diversity capabilities available for the dual SCU models (6700 & 6600(M)) uses both SCUs to digitize two diverse RF signals from separate antennas and the receivers are synchronous (the core requirements for diversity reception). If full duplex is off, then the antenna not assigned to the transmitter is switched out of the RF signal path.2
Are RXA and RXB switched out when duplex is off and transmitter is keyed?0
Yes.0
Many thanks next when approved for sale in EU
Neil G0GGG
The radios have CE approval. We will begin shipments to our dealers in the coming weeks. It shouldn't be too long now.0
Thanks for all the information, now ordered M&L looking forward to enjoying the Flex hopefully quite soon
OK, am I correct in assuming that if I:
- press the Diversity button on SSDR,
- have my main RX and TX on ANT1 (Ant1 is an OCF dipole) and
- Ant2 (same band vertical about 150 feet away) connected to the other SO239 connection
that the second SCU is safely disconnected/grounded or otherwise protected when Ant1 goes into transmit? I usually run a 1200 watt amplifier on Ant 1
I have searched the Community and found this answer but want to be sure.
NEVER MIND...I read Tim's response above and that if full duplex is off, the the 2nd ant is taken out of the RF path with the 1st ant is used for TX.
I sure would like to hear the answer to Bill's question on whether one antenna port (160M dipole) is grounded when transmitting on the 2nd antenna (160M inv L) when using diversity on a 6600M.
- 246 Community Topics
- 488 The Flea Market
- 7.3K Software
- 328 SmartSDR for Mac
- 241 SmartSDR for iOS
- 224 SmartSDR CAT
- 161 DAX
- 343 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 726 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 369 Remote Operation (SmartLink)
- 118 Contesting
- 116 Amateur Radio Interests
- 810 Third-Party Software
