I am not getting any mic output on my PC
Usually I have this happen when I have inadvertently narrowed the TX audio bandpass (PHNE Panel, TX Filter).0
I have this happen every so often. Changing the Mic Input and/or Profile brings the audio back.
George my low cut is 100 and my high cut is 2800. KF4HR, the input is set on PC. Increasing the mic gain has zero effect. Strangely changing the mic to PC, the mic on the radio is still active. I am relatively sure it is something ****, but as of yet I don't know what it is.
Hi Alan, I have the same problem, see my post three days ago. I changed profile and mic settings, I do not get the PC mic up and running. 73 Henning0
Henning, my meter is not moving and the recorder is not recording my voice.
If you have the DAX button that is under the +ACC button turned ON then the PC MIC will NOT work.
Make sure your MIC is setup as the default in your Windows audio recording device
hope this helps
Bret
WX7Y
I have had trouble with the mic plugged into the computer. It was working fine running remote but I unplugged the microphone from computer and plugged back in. It stopped working. From some past postings there was a thread about Microsoft switching mics when it detects what it thinks is a failure. I rebooted the computer and it came back to normal operation. External microphone worked fine, Heil pro set HC6. As stated above DAX button cannot be pushed, mic must be in PC mic and correct mic should be selected. TX must be Red. I think I need to make a checklist for some of these items. Reboot PC. On computers right click on speaker icon on lower left of desktop and click Sounds, look at recording tab, you should see audio bar kick up when you speak into mic. On external microphone properties you can check settings for mic. Mine is 91 level and +20db. If you configure the external mic you can speak a sentence into your microphone plugged into computers and it will set levels for you. Since I went through the configuration on pc recording audio it seems to be stable. With my headset plugging into computer. By the way on SSB Remote operation I hit mox key then use space bar as my PTT. If you hit another key MOX loses focus an space bar doesn’t toggle MOX until you click on MOX button again. Not used to operating temote yet. New toy. 73 Bill Ahillen W9JJB0
My thanks to those who contributed their ideas. It turns out that the problem was that somehow the mic setting in Parallels got changed. All is well now.0
What is "Parallels"? My PC microphone is not producing AF for TX, but is working in Windows...0
Got it, thank you.0
Wanting to use the Windows PC built in Microphone, Window microphone test shows it is working. Not getting Transmit Audio with MOX and VOX does not key the radio, Running SSDR 3.2.49 Last evening I was able to transmit using VOX, DAX Transmit is turned off. Below are screen shots of SSDR and Windows.
Stumped and looking for help, 73, Terry KC4DV
I was just reading through this and I am glad you got your problem resolved.
However, @Alan - KA4B it is really really important to share your entire setup so that others can give you an informed reply. The more detail you supply, the easier it is to narrow down where it is failing.
If you tell me your mic isn't work, and that is all, I can think of a dozen questions I need to ask to narrow down your configuration issues.
Had you mentioned that you were running Windows in Parallels on a MAC in the first posting I could have likely solved your issue in 2 questions.
100% of no MIC audio issues are related to either Mic Gain or the wrong Mic input being selected. :)
- 342 Community Topics
- 612 The Flea Market
- 7.9K Software
- 6.3K SmartSDR for Windows
- 407 SmartSDR for Mac
- 266 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 20 Aurora
- 199 FLEX-8000 Signature Series
- 919 Maestro
- 890 Genius Products
- 452 Power Genius XL Amplifier
- 322 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 137 Contesting
- 748 Peripherals & Station Integration
- 138 Amateur Radio Interests
- 970 Third-Party Software
