6000 Series Profiles
Mike-VA3MW
If you are starting to play with Profiles and would like some details, this document like help you out.
http://www.flexradio.com/downloads/smartsdr-profiles-how-to-guide-pdf/
Hi Mike - the link is cut off.0
Thanks Mike, that is my next step when I get around to it0
Your link seems to be to a file on your local hard drive, Mike.
That has to be a record for the quickest reply ever! 8^)1
I fixed the link1
Works now. Thanks.
Thanks Mike,,that is a hole education into profiles.1
Another, old, V1.x how to guide.0
The logic on the profiles hasn't changed between v1 and v2. That is from the author of the code.0
Where are profiles saved? If you have to do a wipe of a 6400M does that wipe the profiles? They are not saved on a computer?0
In the SmartSDR manual, the process for exporting your profiles to your PC is outlined. That way you can import them again if need be.
Thanks for the information. Flex needs a gopher to add V1.x through V2.x to the description of all these .pdf guides.0
I get "404 Not Found" when I click the link above...0
Link is broken.
Web Server Error 404: Oops, This Page Could Not Be Found!0 -
I'm seeing a reorganization of www.flexradio.com happening, that might be the cause of the broken link. The websites getting a refresh, That's a good thing!
For real-time discussions
User created documentation.
Volunteer!!73, Jay - NO5J
I've been backing them up onto a backup drive. It renames the file every time so it keeps the history and there's no overwrite. I've used that feature more than once.....
Jim, WQ2H
A whole new website got loaded last night, so I should’ve waited a day before posting this https://www.flexradio.com/downloads/smartsdr-profiles-how-to-guide/0
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
- 812 Peripherals & Station Integration
