question
Joe Sartori
no waterfall when running from laptop away from home network
BTW IOS on phone works fine on same network...
Hi Joe
As strange as it sounds, it is a ISP Network issue of some time. Is your firewall on on your computer?
I am uninstalling Norton security now to see0
Norton security uninstalled and firewall is off.. Meters work nd I hear audio. Both Laptop and iPhone on same wireless network now.. (at Work)0
Happened to me as well. Just decrease the size of the window and it should work properly. It’s just a minor decrease. Nothing drastic. Then in the display mode you can adjust the speed of the FPS and the rate of the waterfall to your liking. May have to slow those settings down as your Modem and ISP may not be able to handle all the data flex needs to work at its maximum. Also make sure your PC has the most current version of the software downloaded. Hope this works!!0
In the past I had shown Flex screen shots of that exact problem and had been told that this was because of packet loss. From the release notes I also thought that version 2.3.7 was to have corrected the problem.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 95 Aurora
- 988 Maestro
- 963 Genius Products
- 353 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
