question
Joe Sartori
Joe Sartori ✭✭
edited September 2019 in SmartSDR for Windows
no waterfall when running from laptop away from home network
  • Joe Sartori
    Joe Sartori ✭✭
    edited July 2018
    BTW IOS on phone works fine on same network...
    Mike-VA3MW admin
    edited April 2019
    Hi Joe
    As strange as it sounds, it is a ISP Network issue of some time.  Is your firewall on on your computer?
  • Joe Sartori
    Joe Sartori ✭✭
    edited July 2018
    I am uninstalling Norton security now to see
  • Joe Sartori
    Joe Sartori ✭✭
    edited July 2018
    Norton security uninstalled and firewall is off..  Meters work nd I hear audio.  Both Laptop and iPhone on same wireless network now.. (at Work)
  • Rick Wykoff
    Rick Wykoff ✭✭
    Happened to me as well. Just decrease the size of the window and it should work properly. It’s just a minor decrease. Nothing drastic. Then in the display mode you can adjust the speed of the FPS and the rate of the waterfall to your liking. May have to slow those settings down as your Modem and ISP may not be able to handle all the data flex needs to work at its maximum. Also make sure your PC has the most current version of the software downloaded. Hope this works!!
  • John - K3MA
    John - K3MA ✭✭
    edited July 2018
    In the past I had shown Flex screen shots of that exact problem and had been told that this was because of packet loss.  From the release notes I also thought that version 2.3.7 was to have corrected the problem.
