Stacks for Flex
Noticed that when I use Stacks for flex and I have "active radio slice enable tx" enabled when I switch bands the TX select will switch from band to band real fast and relays start clacking inside the rig like it don't know what slice is supposed to be active. As soon as I end program the issue is gone.
Anyone else notice this anomaly??
That is interesting, sounds like another thing for the author off Frstacks needs to look into?
Steve, how did you make out not being able to buy a radio? have been wondering0 -
No. I've been using FRStack since it first came out and have never had an issue with it, although I don't normally use that option. When I just tried it, I get a single click as I change panadaptors, which would be expected as the radio enables transmit on the new slice and adjusts the ATU accordingly.0
The way it is happening to me is I have both slice a & b on 40 meters. I'll have transmit on slice b. when I switch slice b to a different band it will go crazy like it does not know which slice is supposed to be active transmit.
I have had this scanning issue happen to me in the past and in my situation it only happened when using it along with the K9DUR MONITOR APP. My conclusion was they worked fine togeather on an identical pc so it must have been something with that particular pc.0
Funny thing is that it NEVER happened with my 6300
I purchased a 2 month old one from a ham that purchased 2. Did warranty transfer and all OK. I was well taken care of by Flex.
Only thing I notice with the 6400 is the receive is quieter than the 6300 but for some reason when I shut down computer or maestro or switch from 1 to the other the volume goes full blast.0
Good to hear, hmmm, must be something telling the sound to go up, a program? maybe persistance?0
This is most likely the interaction between two FlexAPI clients. Try running only SSDR and FRStack on the PC. Have no other programs running. See if the issue persists. If it does not then you have to find the other client that creates this scenario. If it does then contact me directly via the Help menu link in FRStack. I will need to know version numbers of all the software you are running.
73.0 -
It seems to be an issue with running FR Stack and k9dur memory manager. When I close memory manager all is fine
Fr Stack 2.2.8.11Memory Manager 3.2.1
What version of SmartSDR?0
Latest0
When I open up Sacks3 for Flex, 3.1.7.27 latest version, it recognizes my Flex Radio, displays the A-B slice, looks to be operating OK!!
On my Flex 6600M radio, I see the FRstack symbol on the screen, if I touch it, it expands out to show other functions.. So on the surface everything seems OK, However I am not getting any Ham Call Signs being displayed.. Flex Menu is configured for Spots, that looks good, and Spots are checked in the View Screen..
This is with SSDR not running, but even if I open it up, makes no difference.. I know this worked when I tried it a few months back..
I noticed that when you highlite Slice A or B in FRstack, it shows DAX-0 for both slices...
Is this something I may be doing wrong, or could this feature be Off Line??
Robert0 -
FRStack supplies a menu system via SPOTS to extend radio functionality, it is not a spot source. I use DX Lab Commander and N1MM to add spots to the SmartSDR display.
Mark,,, Is their any Videos or information on how to set this all up??0
- 245 Community Topics
- 490 The Flea Market
- 7.4K Software
- 327 SmartSDR for Mac
- 243 SmartSDR for iOS
- 224 SmartSDR CAT
- 163 DAX
- 347 SmartSDR API
- 8.5K Radios and Accessories
- 768 Maestro
- 42 FlexControl
- 727 Genius Products
- 251 Tuner Genius XL
- 84 Antenna Genius
- 222 Shack Infrastructure
- 149 Networking
- 118 Contesting
- 116 Amateur Radio Interests
- 811 Third-Party Software
